Just found THIS!!!
Has anyone else seen these?
600 dollars for 12 inch big brakes and they are Wilwood!!!!
4 piston caliper that weighs about 3 lbs. Aluminum hat with steel rotors. I just think that is crazy!
Powerslot also makes this kit for about 400 bucks. It also has 12 inch rotors but uses a caliper relocation bracket instead. I don't like the idea of having a single piston caliper when a 4 piston caliper is available for only 200 bucks more.
Anyone use their stock civic brakes for track stuff with no problem. My old 89 honda civic with new calipers and OE spec brembo flat rotors stopped HELLA good compared to my EP3.
Any input would be great.
The wilwoods you can get at andysautosport.com
the powerslots you can get at like any NAPA. I am pretty sure. I work for napa and I can get powerslots.
Or tirerack has them too.
Just look around.
I would hit up the wilwoods for only 200 bucks more.
Just look around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Earthworm Jim »</TD></TR><TR><TD CLASS="quote">Here's a better deal:
http://fastbrakes.com/shop/pro...d=359</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Earthworm Jim »</TD></TR><TR><TD CLASS="quote">Here's a better deal:
shamoo
25
May 31, 2002 09:54 PM
