Suspension & Brakes Theory, alignment, spring rates....
Preloading radius rods on a CRX with FullRace traction bars??
Old Dec 31, 2007 | 02:13 PM
SIred91's Avatar
Rainman
Default Preloading radius rods on a CRX with FullRace traction bars??
Does anyone know how or what to do other than just bolting everything on?
Old Jan 1, 2008 | 07:38 AM
DaveF's Avatar
Default Re: Preloading radius rods on a CRX with FullRace traction bars?? (SIred91)
put it on an alignment rack to set it up properly
Old Jan 1, 2008 | 07:05 PM
SIred91's Avatar
Rainman
Default Re: Preloading radius rods on a CRX with FullRace traction bars?? (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">put it on an alignment rack to set it up properly </TD></TR></TABLE>
Im aware of having an alignment done after install.....and have everyday access to a rack.....But what about pre-loading the radius rods?
Old Jan 2, 2008 | 02:28 AM
DaveF's Avatar
when you "pre-load" the radius arms, then you will affect your caster... unless you have proper means of measuring this, then it should be done on an alignment rack....
Old Aug 16, 2008 | 06:10 PM
95dxsir2's Avatar
according to my traction bar install instructions. i don't have them in front of me, but i do remember what it says. install the main bar, tighten. Install radius arms to lower control arm and main bar. Tighten. preload the radius arms by turning by hand until drag is felt. tighten lock nuts.
jesus [freak] this is old
i was searching, my bad
Old Oct 8, 2010 | 11:48 AM
vavoom's Avatar
i am still unsure as to how the brackets on the lower arm should go can anyone for the eg civic. can anyone help the full race site show 2 different settings which one is correct?
Old Oct 8, 2010 | 05:58 PM
lzyga09's Avatar
just call the manufacture of the traction bars, they should help you out
97Preludeguy
May 18, 2010 06:10 PM
BlueRex1020
Oct 8, 2006 12:50 PM
HT Chaplain
Mar 1, 2006 06:43 PM
Wraith
10
May 2, 2005 06:54 AM
Kwuaymaikrup
Apr 10, 2003 08:02 AM
