Momo pedals install...help
I bought some momo petals to put on my ep3 a while back so finally today i figured I would put them on well I did the clutch and the brake with no problem..you have to drill 2 holes for them...but the gas pedal doesnt have a pad like the other two do that you can just slip off..its like one whole assembly i just didnt know if it would be ok to drill through it or not?
The gas pedal is partially plastic. When I installed my Mugen pedals, I had to cut some of the plastic off, then I just screwed the pedal into the metal part.
same here, i got momo pedals awhile back, and i'm pretty sure i drilled through the medal to put them on. and also some of the screws they gave me were to big so when i stomped on the gas, it wouldn't go all the way down, so watch out for that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey funk »</TD></TR><TR><TD CLASS="quote">it wouldn't go all the way down, so watch out for that.</TD></TR></TABLE>
Same with me when I helped my brother install his Type-R Replica pedals. The dead, clutch, and brake pedals were easy. On the other hand, when my brother drilled the gas pedal it wouldn't go all the way through. So he drilled it at the point where it's enough that the screw can be intact, and not be loose.
Nonetheless, it was a mission. Good luck!
djsire
17
Feb 22, 2006 12:29 PM
