JDM SiR2 Fusebox diagram Needed!
I have the Haynes manual but this is for UK spec 5 DR and the fuse numbers etc are different to the JDM version. I can't read Japanese so am a bit stuck.
Basically since ive owned the car the interior lights, cig lighter light, seat belt light have never worked and today i tried to wire up some gauges and blew yet another fuse this time the dash clock lights!
For example the diagram i have says number 4 fuse is side lights so when i stick a fuse in there the car starts beeping at me! Turns out its the door open warning noise that has never worked since ive had the car.
It's been off the road for a while now so i want it all sorted once and for all.
So if anyone could either list the fuse box numbers, ampage, and what the hell it is that would be a great help!
Do you have the Japanese diagram? If so, post it up. Someone might be able to help translate it. And if it does, then I can make a replacement for it and list the info for the car in my fuse diagram thread.
DxBurnoutKing
Dec 20, 2005 04:30 PM
