B20 suggestions....
Old Dec 30, 2007 | 11:18 PM
cova12's Avatar
Default B20 suggestions....
I am buying a B20, and getting a B16 head. The thing I am wondering is should I do anything to the bottomend or leave it stock. I don't have gobs of money lol so I gotta be realistic with myself. Its a project car but hopefully when I am done it will be a dd!
I was wandering.....would I have to get the cylinder walls bored for B16 pistons or would yall use different pistons or just keep the stock to save money. I hear people saying stuff about piston clearance issues and stuff like that. My buddy said if I keep the stock pistons I would lose a lot of power. Help me out fellas this is gonna be my first REAL build. My other cars have just been bolt-on items and body work.lol
Old Dec 30, 2007 | 11:48 PM
mr.speaker's Avatar
Default Re: B20 suggestions.... (cova12)
B20 has an 85mm bore,all the other b-series have 81mm.
IMO the only thing the bottom end needs is different rod bolts,arp makes a good set.
Old Dec 31, 2007 | 01:06 AM
My_EFsedan's Avatar
Default Re: B20 suggestions.... (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">B20 has an 85mm bore,all the other b-series have 81mm.
yep. leave the block stock (unless u going turbo?) im in the process of doing a b20vtec myself, all i need is a head gasket and im ready. my bros b20vtec stock internals in a crx ran a 12.6 best time. btw both cars are DD..
Old Dec 31, 2007 | 04:04 AM
Chris Tune's Avatar
change 85 with 84 and you are right...
Old Dec 31, 2007 | 05:12 AM
cova12's Avatar
Default Re: B20 suggestions.... (My_EFsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My_EFsedan &raquo;</TD></TR><TR><TD CLASS="quote">
yep. leave the block stock (unless u going turbo?) im in the process of doing a b20vtec myself, all i need is a head gasket and im ready. my bros b20vtec stock internals in a crx ran a 12.6 best time. btw both cars are DD..</TD></TR></TABLE>
What ecu are you running? And is ypur brothers tuned? What tranny is he using? 12.6 is bad *** stock!
Old Dec 31, 2007 | 07:26 AM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">
change 85 with 84 and you are right... </TD></TR></TABLE>
Dont know why I put 85.
Old Dec 31, 2007 | 07:38 AM
mar778c's Avatar
Community Builder
Community Influencer
I would bore and hone to 84.5 mm and replace with rs machine pistons.
Also, I would replace the oil and water pumps with new 98+ spec b16a equipment and get a gsr timing belt.
Almost forgot, replace the bearings with ACL tri-metal.
Modified by mar778c at 1:37 PM 12/31/2007
Old Dec 31, 2007 | 01:18 PM
My_EFsedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cova12 &raquo;</TD></TR><TR><TD CLASS="quote">
What ecu are you running? And is ypur brothers tuned? What tranny is he using? 12.6 is bad *** stock!</TD></TR></TABLE>
my bro and i build his 1st b20vtec about 4 years ago..
stock 98 b20b block
stock 1st gen SiR b16 head
aem cams
aem fuel reg
aem fuel pump
itr intake
itr manifold
itr header 4-1
J1 b16 cable tranny
act 6 puck
fidanza 7lb fly
no rev limitor obd0 ls ecu
tuned by BsR at 191hp/157trq, yes stock internals.
ran a 12.6 best time at scaramento raceway..89 crx full poly wings west kit, full si interior on 22/14/8 m/t slicks open headers..
ran good for about 3.5-4 years before the head gave out (valves dropped and cam shaft seized up to the head)
in Feb 07 we build another b20vtec for his 91 wagon..
stock 99 b16 head
same stock 98 b20b block
b16 tranny grind 3rd and 4th!
act 6 puck
fidanza 7lb fly
str cams
aem fuel reg
stock intake box
stock usdm type r headers
no rev limitor
ran a 14.0 on 22 slicks open headers, full interior. untuned and grinded 3rd and 4th..sold the car about 3 days ago
Old Dec 31, 2007 | 02:18 PM
Stinkycheezmonky's Avatar
Suspetise...
Have you dynoed the second rebuild? That first one seems like outrageous numbers for what you've done.
Old Dec 31, 2007 | 03:05 PM
My_EFsedan's Avatar
Default Re: B20 suggestions.... (Stinkycheezmonky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">Have you dynoed the second rebuild? That first one seems like outrageous numbers for what you've done.</TD></TR></TABLE>
no the second one was never tuned..seen the track only twice and the car was traded for a mint EG..everyone that was there for the 1st setup dynoing was suprise that is made that much, alot of people on hondatech dont believe that my brothers stock internal b20vtec put out that much power..but it did. ask Chad Barber himself..
Old Dec 31, 2007 | 03:16 PM
Bury Your Dead's Avatar
* B A N N E D *
so tell me about those AEM cams....
Old Dec 31, 2007 | 03:17 PM
Suspetise...
What kind of dyno was it?
Old Dec 31, 2007 | 03:19 PM
* B A N N E D *
Default Re: B20 suggestions.... (Bury Your Dead)
if you are buying the b20, why dont you take your time? are you in a hurry? just take you time.
do it right the first time, or do it twice if you know what i mean.
Old Dec 31, 2007 | 03:29 PM
Chris Tune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bury Your Dead &raquo;</TD></TR><TR><TD CLASS="quote">so tell me about those AEM cams....</TD></TR></TABLE>
LOL
Old Dec 31, 2007 | 03:32 PM
My_EFsedan's Avatar
they suck *****, they tend to loosin up the screws, thats why we got the STR cams instead
Old Dec 31, 2007 | 03:38 PM
Suspetise...
I'm guessing he means camgears, not cams. Right?
Old Dec 31, 2007 | 03:40 PM
* B A N N E D *
they suck *****, they tend to loosin up the screws, thats why we got the STR cams instead</TD></TR></TABLE>
oh seriously? whats the duration on the new STR cams? bet they are wicked with all that power you guys are making.
do you have pics of that body kit? i was thinking of getting the shogun samurai sword body kit for my crx and build a b20 with str cams but im not sure if they will work with my supra tails. need some "go" with all that "show". know what im sayin home-slice?
Old Dec 31, 2007 | 03:56 PM
My_EFsedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing he means camgears, not cams. Right?</TD></TR></TABLE>
yes camgears, the STR cams that was put in there was on the second build and it wasnt a tuned motor so the Cams were never adjusted..
Old Dec 31, 2007 | 08:58 PM
JDM JEFFREY's Avatar
str did not make cams..........
what cams did u have in the motor..
camgears are not the same as cams....
Old Dec 31, 2007 | 09:12 PM
PyroProblem's Avatar
Default Re: B20 suggestions.... (JDM JEFFREY)
Just get throw some arp rod bolts in there with some RS pistons and with machine work youll still probably be under $500.
If your going N/A, you want more compression than what the stock pistons are gonna give you.
(my opinion)
Old Jan 1, 2008 | 01:06 PM
Chris Tune's Avatar
do you have pics of that body kit? i was thinking of getting the shogun samurai sword body kit for my crx and build a b20 with str cams but im not sure if they will work with my supra tails. need some "go" with all that "show". know what im sayin home-slice?</TD></TR></TABLE>
that would be a very nice car... seriously.. show and go and all that mad tite ****
Old Jan 1, 2008 | 05:34 PM
My_EFsedan's Avatar
Default Re: B20 suggestions.... (Chris Tune)
this is my brothers old crx with the 1st b20vtec setup..
dont mind the graphics..
Old Jan 2, 2008 | 02:32 AM
Ferio3399's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">change 85 with 84 and you are right... </TD></TR></TABLE>
I knee down and bow to Chris!!
Old Jan 2, 2008 | 02:38 PM
Mhollaek9's Avatar
r u guys using bottom end gasket kits and where do you find em?
Old Jan 2, 2008 | 02:46 PM
Mhollaek9's Avatar
Whats a better header for a built b20vtec I'm on a budget do its down to profAb or hytech replica? TIA
SolAssassin
Oct 21, 2007 05:07 PM
cacahead1
Jan 31, 2006 07:26 PM
theSQad
19
Feb 11, 2004 12:12 PM
vti2
Dec 2, 2003 04:28 PM
