Need help with DOHC ZC
Old Jun 28, 2002 | 07:45 PM
whatREDLINE's Avatar
Default Need help with DOHC ZC
Hey guys, need a little help here. Ive got a DOHC ZC motor that I'm rebuilding due to bad rings. The problem is, I don't have any torque specs for the motor to rebuild it. If anyone has a chilton manual, or knows the torque specs for the valve train and bottom end it would be greatly appreciated.
I'm tearing it down as we speak, so if any of you can help, or know where I can find any good information it would be greatly appreciated. If anyone has the a manual or knows where to get one I'd buy it immediately.
Thanks in advance.
Old Jun 28, 2002 | 08:03 PM
Bgladfelter's Avatar
Default Re: Need help with DOHC ZC (97D3S16Npro)
http://66.24.150.222:7080/manual/2gsm/engine_block.htm
for a CRX motor, but should be same one. If not, helminc.com 88-9 Integra.
Old Jun 28, 2002 | 08:40 PM
Default Re: Need help with DOHC ZC (Bgladfelter)
I realized now that i need the torque specs for an 88-89 intgegra DOHC (D16a1 or D16A3), for same as above.
Old Jun 28, 2002 | 09:13 PM
let's put it back up on top
Old Jun 28, 2002 | 09:32 PM
MrTodd's Avatar
Hold on - Don't use torque specs from the D16 models!!! I know the D16A is very similar, but some things are different! I found a site that's based in England. Here's the link - http://www.hondacrx.co.uk/
Go to the <U>Downloads</U> section, and download the CRX Workshop Manual. This manual is based on the 1.6i 16v CRX, which is the car in england that had the ZC engine stock. The manual is in PDF format, and it has EVERYTHING you need!
Hope this helps!
Old Jun 30, 2002 | 12:36 AM
3RROR404's Avatar
Default Re: Need help with DOHC ZC (MrTodd)
MrTodd, you are the MAN!
racingcrx
Apr 9, 2006 06:51 AM
kevtegra
Aug 3, 2005 08:52 AM
HondaKPX
Aug 15, 2004 02:32 AM
Ronin Panda
Jun 3, 2003 03:14 PM
joey1320
Mar 21, 2003 01:58 PM
