eg hatch questions
Old Dec 30, 2007 | 08:45 PM
wicked_b16eg's Avatar
Default eg hatch questions
Car: 1995 civic hatch cx
1. Will 2dr fenders,hood, bumper, side skirts fit?
2. What motor mounts can I use from a sohc for a b16?
3. What Fuel rail can I use for a GSR head?
4. What model do I need for lower control arm and steering knuckle?
Thanks
Old Dec 30, 2007 | 08:56 PM
ca-rs's Avatar
Default Re: eg hatch questions (wicked_b16eg)
Fender, hood bumper will fit, side skirts will not.
Old Dec 30, 2007 | 08:58 PM
Default Re: eg hatch questions (ca-rs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ca-rs &raquo;</TD></TR><TR><TD CLASS="quote">Fender, hood bumper will fit, side skirts will not.</TD></TR></TABLE>
Thanks..
Anyone know about the rest?
Old Dec 31, 2007 | 07:40 PM
EG6 Poe's Avatar
SOHC motor mounts will not fit a B series at all!!!!! You need B series mounts from the del sol or integra.
Any B series fuel rail will fit
Old Dec 31, 2007 | 08:45 PM
crazyguy's Avatar
Default Re: eg hatch questions (EG6 Poe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 Poe &raquo;</TD></TR><TR><TD CLASS="quote">SOHC motor mounts will not fit a B series at all!!!!! You need B series mounts from the del sol or integra.
Any B series fuel rail will fit</TD></TR></TABLE>
actually the rear mount is the same but T bracket is different.
Old Dec 31, 2007 | 10:04 PM
4gencivicef9's Avatar
It actually depends on the fuel rail they all will fit that is correct, BUT the FPR location will expletive you cause it can be in the way of the intake temp sensor so you can't plug it in and it will be a bitch with hooking the hose up to the FPR....so beware..
the mounts they our so back and forth with mounts like you need the ac comp bracket from a b to run the lower frame mount, then you need a b series tranny bracket to run the other side lower frame mount. you need a DC rear bracket DC rear mount, the others not really sure you our going to need integra axles, integra linkage, teg half shaft, basically any bseries 94-01 integra or 99-00 civic si or 93-97 del sol Vtec
you do not have to switch LCA's or hubs or steering knuckles for the swap...
maza849
Honda Civic (2001 - 2005)
May 13, 2007 11:18 PM
RHD DA6
Apr 3, 2007 08:49 PM
INCNTRL4
Nov 13, 2005 11:15 AM
d1deez
Aug 24, 2004 12:46 PM
jaminonyourface
Oct 20, 2003 07:43 AM
