Starter question *searched teh web thoroughly*
Old Dec 30, 2007 | 05:19 PM
USDMSiR's Avatar
Default Starter question *searched teh web thoroughly*
I need to know for sure what starter will work in a manual B16 OBD0 (out of a CRX SiR). I researched and found conflicting beleifs. One was that all B series starters work and one that only certain ones work. I need to know because i have to buy one here asap. I am poor and cant be wasting money on a starter that wont fit. Thank you in advance for the help.
Old Dec 30, 2007 | 09:43 PM
crxcess's Avatar
Default Re: Starter question *searched teh web thoroughly* (USDMSiR)
i looked on ebay for integra starters. I see seperate listings. different listings depending if the trans is a hydro and cable setup. if you get a 90-93 manual trans starter, you'll probably be fine.
Old Dec 31, 2007 | 08:35 AM
USDMSiR's Avatar
Default Re: Starter question *searched teh web thoroughly* (crxcess)
sweet thanks. Im getting a starter from a friend for 50 bucks. hopefully all is well
Old Dec 31, 2007 | 09:35 AM
alscrx's Avatar
its said that a civic si or del sol starter will work. if i were you i would use an 90-93 integra LS starter. Its the closet thing to a early b series block and tranny
Old Dec 31, 2007 | 09:37 AM
CRX_Banned's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMSiR &raquo;</TD></TR><TR><TD CLASS="quote">sweet thanks. Im getting a starter from a friend for 50 bucks. hopefully all is well</TD></TR></TABLE>
test it at napa and see if it passes. If it doesn't your friend taking advantage of you selling crappy parts. Beat that fool up and refund it.
Old Dec 31, 2007 | 10:12 AM
turboZChatch's Avatar
Default Re: Starter question *searched teh web thoroughly* (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">its said that a civic si or del sol starter will work. if i were you i would use an 90-93 integra LS starter. Its the closet thing to a early b series block and tranny </TD></TR></TABLE> 90-93 integra will work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_KING &raquo;</TD></TR><TR><TD CLASS="quote">
test it at napa and see if it passes. If it doesn't your friend taking advantage of you selling crappy parts. Beat that fool up and refund it. </TD></TR></TABLE> hahaha your a clown
Old Dec 31, 2007 | 10:31 AM
DontFlameMeBro's Avatar
I have a B16 odbo in my crx. When the starter went out i pulled one from a 90-93 ls at the junkyard and it works fine. Although it is physically a little larger than the B16 starter.
brian1991
11
Apr 21, 2023 01:58 PM
Drummerkid51
Transmission & Drivetrain
Dec 23, 2013 01:34 PM
vongoetze
Mar 22, 2008 07:48 PM
sicivic
Jan 28, 2008 04:42 AM
Soichiro-son
Apr 10, 2007 09:41 AM
