Removing Alarm system on 1990 Si. A little help please?
Old Dec 30, 2007 | 04:57 PM
Arthas's Avatar
Default Removing Alarm system on 1990 Si. A little help please?
Hello all.
I have an after market alarm system installed in my car and its been **** ever since I got it. The control sucks and I lost it but now I cant turn on my car because the alarm is also a kill switch. Anyone know the usual spots that people put the alarm modules or something? I really want to remove the alarm system and install a better one later on.
Thanks!
-Arthas.
Old Dec 30, 2007 | 05:06 PM
CRXBart's Avatar
Default Re: Removing Alarm system on 1990 Si. A little help please? (Arthas)
Under the dash tied into the igniton harness.
Old Dec 30, 2007 | 05:07 PM
dr_latino999's Avatar
Look under the dash, and start looking for anything that isn't supposed to be there. Once you identify a power line or the sorts, follow it back.
Old Dec 30, 2007 | 06:07 PM
Arthas's Avatar
thanks, I'll try it out
Old Dec 30, 2007 | 08:20 PM
Arthas's Avatar
Follow it back to where? And what do the cables look like?
Are they crimped on or something?
Old Dec 30, 2007 | 08:28 PM
90sedan's Avatar
Default Re: (Arthas)
It depends on the type of alarm and the type of install. If it was a good stealth install, then it will probably take you some time to find it, otherwise it should be right underneath the dash.
More than likely it was a cheap install, so just look directly underneath the ignition column and near the fuse box for any wires that are not factory loomed. Trace those wires and you should be able to find the alarm brain. Again depending on the install, the wires could be soldered, crimped, or twisted together.
It will basically come down to you just spending some time underneath the dash. If all else falls, take some pictures and we'll be able to help you find it.
rancidhooligan
Audio / Security / Video
Nov 14, 2007 05:02 AM
wrx-killer-Sti-eater
27
Feb 18, 2007 07:37 PM
mickey513
13
Jul 17, 2006 02:02 PM
k7q
Mar 6, 2006 01:57 AM
Takeoff
Jun 11, 2002 12:40 PM
