how much shorter RACE SPSS3
Fronts are 25mm shorter, rears are 15mm(?) shorter. Not sure on the droop limiter change, though I can't imagine longer droop limiters being used. Most of us don't care about droop limiter length as the rates we run are so stiff the shock has more droop range then the spring does. For your car, you might want to give Koni a ring and find out. Topping a shock out is as bad for grip as bottoming the shock out.
bojangs
34
Apr 28, 2003 11:08 AM
bearboy80
Apr 17, 2003 01:58 PM
