how can i install a car alarm on a 1996 civic
https://honda-tech.com/zeroforum/27
look under How-to and which alarm i should buy thread. There's alot of information there..
i know for sure black with white line is starter, black and yellow is switched 12v , and white is constant 12v , those would be your main cables plus ground and then the red with black on the back of the dimmer switch controls your parking lights if you have power door locks there are two cable in the driver kick panel to activate it with your alarm i believe it light green with orange and light green with red ones unlock and the others lock... grab a test light ground it and check for power and for the door locks if you pinch them with ground they will either open or close... if you have no clue wat your doing with wiring dont intent to do it cuz youll hate your self later g/l
Modified by redb16coupe at 6:25 PM 12/30/2007
intezn
Audio / Security / Video
Aug 6, 2003 05:39 AM
