fuel pump not running
i just finished up my wire tuck last night. i went to start my car but did not hear the fuel pump humming. its not getting any power to the plug at the pump. i had the same problem when i put my b16 in but i just turned the switch back and forth about 10 times and it started humming but thats not workin this time. my question is can my ignition switch be bad or what can be goin on? i have checked the wiring to the pump and looks fine. maybe i over looked something but im not sure. thanks
sounds like it is time to break out the circuit tester. If the car ran fine before the wire tuck, you forgot to plug something in or wired something incorrectly.
