SRS light popped up
Old Dec 30, 2007 | 10:12 AM
shadohconspiracy's Avatar
Default SRS light popped up
ok so i was driving home yesterday and then the SRS light turned on for like 5 seconds then it turned off. anyone know what this means , or is it just a fluke?
Old Dec 30, 2007 | 10:44 AM
Panda Eg6's Avatar
Default Re: SRS light popped up (shadohconspiracy)
bump. idk happend to me in my old TEAL civic as well hehe
Old Dec 30, 2007 | 10:45 AM
black0hatch's Avatar
hmmm i would look into that it would suck if that air bag just poped out in your face. i used to detail trade ins and some dude told me one went off in his face and broke his nose. i know theres a thread on here on how to turn the light off. you should be able to check codes like you would for a cel.
Old Dec 30, 2007 | 12:33 PM
97Ej6mike's Avatar
When you first start your car, the SRS light comes on for about 5 seconds. YOu sure you didnt accidently flip the car off then on again while driving? While driving, flip from 2nd to 1st accesory, then back again to second, and ur srs will come on for 5 seconds as it runs its test.
Old Dec 31, 2007 | 05:36 AM
i was thinking that could of been what happend but, im pretty sure if my car turned off i would notice..... hmmm ya it would suck if the airbag went off on my face not only would it scare the **** out of me but it might cause some damage haha
but i drove for a bit today and the light didnt come on, ill definetly look more into it if it turns on again. thanks
Old Jan 4, 2008 | 05:24 PM
ej_type_R's Avatar
Turn the car off, stick the key in the ignition and turn it all the way to the last notch but dont start the engine.
Look at your SRS light. If it flashes for about 6 seconds and then disappears, your SRS should be fine. If it just flashed once, it's an intermittent error, at least for now. You should be OK if that was the only time it flashed. (someone correct me if I'm wrong, but I believe that's what the Helm's manual says).
Old Jan 4, 2008 | 05:50 PM
speedy_beedee's Avatar
that what mine did but after a week it stayed on, you should still report this glitch.
https://honda-tech.com/zerothread/2190965
Old Jan 6, 2008 | 04:41 AM
ej_type_R's Avatar
Default Re: (speedy_beedee)
If it just came on that one time, your SRS should be fine.
Old Jan 6, 2008 | 08:20 AM
boosted_EM1's Avatar
Default Re: (ej_type_R)
my srs light never came on. then one day driving down the road they went off
maybe it did come on and i didnt see it but its on now.
Old Jan 6, 2008 | 08:48 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (boosted_EM1)
mainly when a cel,srs light just flashes or comes on and goes off its normally a intermittent failure. so you should be good unless the light comes on and stays on then go get it checked cause that means non of your srs will operate correctly
AZMyst
Apr 26, 2005 09:50 AM
StolenTeg
Nov 28, 2004 08:19 AM
Brakiss
Aug 17, 2004 01:00 AM
brianlmoon
Jul 25, 2004 08:17 PM
