code 22 (oil press) check engine light in PR3
Old Dec 30, 2007 | 09:53 AM
crx_si-r's Avatar
Default code 22 (oil press) check engine light in PR3
ok so i took some advice that i received earlier about where to get my PR3 obd0 ecu chipped, and i went with john over at j-k-tunning.com and after i installed the chip i immediately received a code 22, which is a oil pressure sensor. only one i can think of is the vtec press. sensor, but here is the kicker; with my stock pr3 i never received this CEL? could it be a faulty chip? john has been tellin me to ground it out, but im thinking this is a bad idea. has anyone ever come across this problem? thanks in advance guys.
Old Dec 30, 2007 | 09:59 AM
GSX 4G63T's Avatar
Check for a loose connection plug on the oil pressure sending unit switch. And check that you having sufficient oil in your crankcase. May be that you are low in oil or the oil pump is giving out.
Old Dec 30, 2007 | 10:08 AM
crx_si-r's Avatar
Default Re: (4163175587)
i have enough oil i did an oil change last week. plug is good. and im runnin a brand new oil pump.
mcewen
Honda Civic (2006 - 2015)
May 23, 2018 06:03 AM
RIPPO
Dec 22, 2005 07:25 AM
Roi
22
Nov 17, 2005 10:01 PM
Immanuel
Aug 8, 2005 02:50 PM
ekdriven
Jul 12, 2004 01:45 PM
