H22 swap question...automatic
Old Dec 29, 2007 | 08:21 PM
piscorpio's Avatar
Default H22 swap question...automatic
Normally I would always opt for a manual transmission over an automatic, but I was wondering if swapping an automatic H22 into an EK or EG presented any extra difficulties over swapping a manual version. I am assuming the auto H22 would be going into an auto EK or EG.
I know this is probably a very unpopular option, understandably so, but I was curious if anyone had an answer...searching didn't turn up much, for obvious reasons.
Old Dec 29, 2007 | 08:29 PM
97Ej6mike's Avatar
First concern in my mind would be the mounting. Auto and manual trannys have different mounts, so i dont know if they make one for the H22 in any 92-00 chassis. Im sure its quite possible with some custom work and know-how with a welder.
Old Dec 30, 2007 | 06:34 AM
piscorpio's Avatar
Default Re: (97Ej6mike)
That's kind of what I figured too. Just wondering how much custom work would be needed.
Old Dec 30, 2007 | 02:51 PM
boostedblkef's Avatar
Default Re: (piscorpio)
the mounts are different you basically would have to make your own mount on the pass side there alot of wiring problems with auto h22's i beleive theres a tcm that needs to be wired in to your harness at the ecu correct me if im wrong
curioso
Nov 25, 2008 11:26 AM
jdm ek9 101
Sep 24, 2006 02:23 PM
AccordDohc
Apr 30, 2004 06:58 PM
