help me!!!
ive got a 00 civic with d16 y8 head and a z6 block. today i removed my intake manifold to replace the manifold gasket. i put it back together and it wouldnt start.
so i rechecked every thing i took off and it was all good. i pulled my plugs and they were all wet with coolant.so i ripped off my head to check the head gasket only to find nothing wrong. so i cleaned out the cylinders and put every thing back together only to have the same thing happen again!!!!!WTF????
any body got any suggestions please lmk!!!!! thanks
i retorqued the head after i put it back on. it wasnt gas cause it was green!! i got it to fire but ran like **** and white smoke poured out the exhaust giving me a reason to pull the head!!!
deff a gasket issue, did you have your head milled or anything prior to putting this new one on? Head/block may need cleaned for the surfaces to mate right, and in a worse case the head could have warpage, but idk since it wasnt doing this before. Head/block probably need cleaned.
lifesastruggle
Engine Management and Tuning
Feb 15, 2017 03:22 AM
Wes90civic
Jan 2, 2004 11:16 PM
