What injectors will fit in a ZC motor??
Old Dec 29, 2007 | 06:27 PM
efprojectboost's Avatar
Default What injectors will fit in a ZC motor??
I got a ZC motor and i heard that i can fit 1986-89 integra injectors, but what other car can i take them off of, i have everything except the injectors, if you can help me out that would be great thanks everyone!!!
John
Old Dec 30, 2007 | 06:35 AM
wiZCo's Avatar
Stouts 'n' Scotch
Use 88-91 Civic or CRX Si (D16A6) injectors. Not sure on the Integra ones, every ZC person I know would just recommend the D16A6 ones.
Old Dec 30, 2007 | 07:26 AM
Tippyman's Avatar
Default Re: What injectors will fit in a ZC motor?? (efprojectboost)
Yup, D16a6 injectors.
I have some if you want them, BTW.
Old Dec 30, 2007 | 07:41 AM
ludesrv's Avatar
Any D or B series OBD0 injectors should do with your stock OBD0 harness.
Both D and B flow at 240cc. Same injectors.
Old Dec 30, 2007 | 08:55 AM
Tippyman's Avatar
Default Re: (ludesrv)
Any OBD0 injector will wire up correctly, but I'm not sure if a B series injector will fit in the fuel rail the same as a d-series. If so, go for it.
Old Dec 30, 2007 | 10:02 AM
ludesrv's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Any OBD0 injector will wire up correctly, but I'm not sure if a B series injector will fit in the fuel rail the same as a d-series. If so, go for it.</TD></TR></TABLE>
They do. I ran D16 injectors on my LS as it had come with OBD1 injectors.
Old Dec 30, 2007 | 10:20 AM
hey what up man, do you have the injectors still? and how much do you want for them hit me up 818 9437196
Old Dec 30, 2007 | 10:43 AM
Tippyman's Avatar
Default Re: (efprojectboost)
PM me if you want them.
ohgodbadname
May 26, 2012 02:38 PM
jining
Oct 8, 2009 01:53 PM
Dohc 4door Rye
Mar 2, 2006 11:17 AM
EFwithS2000taillights
Oct 11, 2005 06:57 AM
Morbspeed
Jan 13, 2004 05:51 PM
