intake tubing madeof fiberglass
Old Dec 29, 2007 | 06:25 PM
fg2si!kid's Avatar
New User
Default intake tubing made of fiberglass
not sure if this would be considerd fabrication but i maybe making some intake tubing out of fiberglass i dont have a welder so i cant make it out of alum just wanted to know if you guys think its safe to make it out of fiber glass i have seen them made out of carbon/kev but just wanted to get some opinions on fiber glass tubing
Old Dec 29, 2007 | 07:24 PM
boosstboy's Avatar
Default Re: intake tubing made of fiberglass (fg2si!kid)
if any particles of the fiberglass get sucked in you will start scratching the cyl. walls or can cause a valve to get stuck open enough to cause issues. make sure that it's sealed very well inside.
Old Dec 29, 2007 | 07:38 PM
fg2si!kid's Avatar
New User
Default Re: intake tubing made of fiberglass (boosstboy)
what do you mean by sealed, i plan on doing a good couple layers so its nice and strong sanding it all down real smooth and panting the out side only
Old Dec 29, 2007 | 07:57 PM
boosstboy's Avatar
you will need to make sure you have a sealer of some sort that will cover the fibers inside the intake, you need to make sure it's flexible as well so it doesn't chip from hitting or vibration and get sucked in. y don't you buy just a cheap intake for now? i personally wouldn't make a fiberglass intake when you can get a cheap used one, or autozone even has cheap aluminum ones.
Old Dec 29, 2007 | 08:09 PM
fg2si!kid's Avatar
New User
iam trying to make a DIY intake plus i have a MAF so i gotta work around that and iam not to crazy about that chrome pipeing they sell at autozone i will be doing some testing before i make it so i dont have problems down the road
Old Dec 29, 2007 | 08:19 PM
boosstboy's Avatar
i would definitely not do this on a newer civic with a maf, if the maf is not in the correct spot or airflow speed is changed drasticly your car will run like a##. it will mess with the way the car sees airflow into the engine and will probely set a maf code.
Old Dec 29, 2007 | 08:25 PM
fg2si!kid's Avatar
New User
the tube will be after the sensor and iam using the stock MAF housing to mount the sensor
Old Dec 29, 2007 | 08:34 PM
boosstboy's Avatar
it should work, but imo i would still buy a decent intake. the risks and time isn't worth it. good luck on the project if you do it
Old Dec 29, 2007 | 08:37 PM
fg2si!kid's Avatar
New User
cool thanks man for the info iam going to start on it first thing in the morning
saemoonyang
Nov 10, 2014 07:20 AM
FakeJDMEF8
Southwest (Sales)
Sep 27, 2011 03:36 PM
jarredwilley
Honda Civic (2001 - 2005)
Aug 12, 2010 08:23 AM
92_ricerintegra
Jan 16, 2010 12:00 AM
