Starter Button installation
I know that they put them on Civics and Miatas, but I was wondering if anyone had a link to online installation instructions for installing an authentic S2000 starter button in my '90 CRX Si. Thanks!!
Guest
Posts: n/a
https://honda-tech.com/zerothread?id=201128&page=2
has a few pics
has a few pics
Some guy put one in his Prelude Si '88. It still requires you tu turn the key to the ready position but instead of turning all the way he pushes a button. He moved to Minnesota so I can't talk to him anymore.
Look for the Prelude Downunder Club of New Zealand. They had a REALLY good modification instruction site which included the wiring of a pushbutton starter.
Why the heck are you desperate to install a pushbutton though? Granted, it's fun, and I intend on doing it somewhere down the line, but desperate?
I'm getting to be annoyed at the "trial users"...
it's very simple. there is a combination switch behind the ignition. remove the 2 screws. you will use 3 wires white, white/black, and black/white. the white and white/black goes on the + side of the switch and the black/white goes on the - side. the down side is if you only hook up the switch you still need the key to disable the steering wheel lock and put the car in the RUN state in order to start. Otherwise you will need the hook up all the other wires to dpst 15 amp toggle switch. here's the link http://www.quickhonda.net/index2.htm and http://www.quickhonda.net/index2.htm. have fun
Heath
Sep 25, 2005 08:39 PM
