205/50/15 on 38 offset wheels?
Old Dec 29, 2007 | 07:01 AM
juall's Avatar
Default 205/50/15 on 38 offset wheels?
Will this work on my eg civic? Lowered 1 inch, with 15x6.5x38 offset. I just didn't want them to rub any. Thanks!
Old Dec 29, 2007 | 09:16 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 205/50/15 on 38 offset wheels? (juall)
On your car you're better off with 195/50-15, which will fit fine on those wheels.
Old Dec 29, 2007 | 09:46 AM
juall's Avatar
Default Re: 205/50/15 on 38 offset wheels? (nsxtasy)
I'd planned on using 195's, but was hoping to go with the 205's so I could get the ASX's. I'll probably go with the summer 195's and use my all season in the winter.
By the way, what is the problem with running summer tires in freezing temperature? What effect or problem does it present? Thanks
Old Dec 29, 2007 | 11:02 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juall &raquo;</TD></TR><TR><TD CLASS="quote">I'd planned on using 195's, but was hoping to go with the 205's so I could get the ASX's. I'll probably go with the summer 195's and use my all season in the winter.</TD></TR></TABLE>
That makes a lot of sense. As you've already noticed, the best all-seasons (like the ASX) are available in 205, not in 195.
I can't tell you about the rubbing, one way or the other.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juall &raquo;</TD></TR><TR><TD CLASS="quote">what is the problem with running summer tires in freezing temperature? What effect or problem does it present?</TD></TR></TABLE>
The colder the temperature, the less grip summer tires have, because they are designed to be used above freezing. You can use them in cold, even extreme cold, when the pavement is dry; they're not going to self-destruct. However, they just won't give you as much traction at those temperatures as all-season tires or winter tires. Similarly, their tread patterns are designed for dry pavement and rain, and are not designed for snow or ice; as a result, they will be extremely slippery on those surfaces, and won't grip as well as all-seasons or winter tires. On snow or ice, they can be particularly treacherous on hills (both uphill and downhill).
Old Dec 29, 2007 | 11:39 AM
juall's Avatar
Thanks for the information nsxtasy, I appreciate it.
Old Dec 29, 2007 | 02:56 PM
jdmhatch1's Avatar
205 will fit fine also
Old Dec 30, 2007 | 07:35 PM
.joeham's Avatar
money folder
My last set of wheels where 15x6.5 +38 and i had 205/50/15 Falken AZENIS RT-615's. Just roll your fender and it wont rub. My new set of wheels are the same size and i plan on using the 205/50 Azenis again for the summer.
Tad
23
Jun 26, 2007 10:15 AM
asmallsol
Aug 21, 2005 12:14 AM
Sound Streamin'
Mar 22, 2005 10:11 AM
Bull
Dec 10, 2004 01:30 PM
Seedc2
Feb 27, 2003 02:43 PM
