FS: walbro, d16y8. y7 trans etc. etc.
need to get rid of some stuff for garage space. pick up only! open to reasonable offer.
1997 d16y8 long block, has 72k on it. runs strong. no intake manifold, no trans, no flywheel/clutch. asking $400 pick up. firm.
1997 d16y7 trans, trans has roughly 75k on it. no grinds, doest not pop out of gear at all, does not have vss. asking $120 pick up.
dseries starter. perfectly good. $30
96 civic hatch back tail lights. these are still in super good condition. no cracks no scratches. $60.
dseries axles. 72k on them. no rips or tears, perfectly good. non abs. $65 pick up.
ssac bseries turbo manifold. used for 500miles. one brace for the t3 flange broke. needs to be rewelded. other wise in very good condition. $45 pick up
ebay axle back N1 style muffler. came off a 96 civic hatch. still new. used for 500miles, still shiny! $50 pick up!
walbro 255 fuel pump, high pressure one. used for 500miles on turbo LS. has sock filter on it. still very new. $ 75.
00 b16 bear block. 55k on it. with crank, and mains, still very good.. was used for boost. was going to send it in for sleeving job but picked up a b18b1 instead. asking $250.
b18a1 bear block, comes with mains and crank. was going to use as spare motor. $150.
set of 96 gsr/se 15" wheels. has tires mounted on them but are way too wore out. needs new tires. rims are painted gunmetal. paint is chiping off. wheels are in excelent condition, no deep scuffs or scratches. 8.5 out of 10. $200
set of 1985 13" corolla wheels. still has tires on them. all 4 are good. one tires has slight camberware. these are not civic bolt pattern. still has original center caps! needs alittle cleaning. $80 pick up!
all located in stevens point, wi. pm me for more details.
Modified by VRD^don at 11:22 PM 1/1/2008
