windshield wipper switch problem
already tried searching didnt find anything so heres my problem
my windshield wippers wont stay on, unless i hold the switch down....two days ago when i turned car on, the wippers go full speed no matter what i do. they wont turn off. now, is it my switch that should be replaced or possible wiring error? my car is a 93 civic sedan with a obd2 integra b18b swap. any help would be great, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dailydrivenHONDA »</TD></TR><TR><TD CLASS="quote">already tried searching didnt find anything so heres my problem
my windshield wippers wont stay on, unless i hold the switch down....two days ago when i turned car on, the wippers go full speed no matter what i do. they wont turn off. now, is it my switch that should be replaced or possible wiring error? my car is a 93 civic sedan with a obd2 integra b18b swap. any help would be great, thanks</TD></TR></TABLE>
yeah, i had this problem on my 93 hatch. it's your switch. it's a easy fix, yu can find the switch at any yard or on ebay. the dealer is going to ask for too much for it.
you do have to remove your steering wheel. it's easy to remove the wheel, just follow airbag removal procedures.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">you do have to remove your steering wheel. it's easy to remove the wheel, just follow airbag removal procedures.
Suck.
For 6th gens you just remove the column shroud, take out the two screws and then pull it out.
</TD></TR></TABLE>Suck.
badfish2282
May 15, 2009 08:45 PM
