HELP!!! i cant get the crank shaft bolt off!
Old Jun 28, 2002 | 03:21 PM
d357r0y's Avatar
Default HELP!!! i cant get the crank shaft bolt off!
its on.. it WONT come off..and i mean wont. impact wrench, air gun, 6ft breaker bar with a 200 plus Lbs guy on it.. that **** is ON there..what ever jakov did the timing belt last put some ******* crazy glue on it or something
any suggestions??
im going to a place that works on fire trucks tomorrow morning because they might have a 3/4 or 1 inch impact wrench... need more torque.. grunt!
thanks in advance
Old Jun 28, 2002 | 04:37 PM
Malgerus's Avatar
Default Re: HELP!!! i cant get the crank shaft bolt off! (d357r0y)
Try using penentrating oil. I Could NOT get my rusted axle nuts off... I mean, we had a 5 foot breaker, and both my brother and I were torquing on it... enough to move the car!!! but no axlenut release. Finally squirted some liquid wrench in, tapped it with a hammer, and BOOM. It cam right off... give it a shot.
Old Jun 28, 2002 | 05:15 PM
d357r0y's Avatar
Default Re: HELP!!! i cant get the crank shaft bolt off! (89_Y_49)
tried it..but im gonna let it sit til morning..if it wont come off then, im going to a big rig repair shop to see if they have a huge impact wrench
Old Jun 28, 2002 | 07:27 PM
Ozzmosis's Avatar
You'll need to take it to a shop that has a good impact gun. Nothing else will remove it. I tried everything in my garage... I ended up renting a compressor, and used my impact gun. It'll take a minute or so of continuous hammering to break it free, but it'll come.
Old Jun 28, 2002 | 09:06 PM
d357r0y's Avatar
Default Re: HELP!!! i cant get the crank shaft bolt off! (Ozzmosis)
nope.. used that impact gun for about 5 minutes straight on it.. nothing..the breaker bar we used was putting more torque on it than the gun anyway.. i put some penetrating oil on it and we will see how that goes tomorrow morning.. if that wont work, its off to the big rig shop for a REAL impact gun.
thanks
Old Jun 29, 2002 | 08:46 AM
bloopie's Avatar
Remember to go Clockwise, not counterclockwise lile when you loosen the rest of the bolts on our cars.. remember that our D Series motors spin counterclockwise, so to loosen anthing you would go clockwise, just as if you were tightening something else on your car.. I had that same problem with mine, then remembered that fact and then we got it off no problemo...
Old Jun 29, 2002 | 09:12 AM
-TJ's Avatar
-TJ
Default Re: HELP!!! i cant get the crank shaft bolt off! (Skunk2ner)
huh? the crank bolt is "regular thread" not left hand. THe only left hand threads I can think of on the entire car are the diff. ring gear bolts.
A bigger impact wrench is only going to beat the **** out of your rod/main bearings even more. Get a gas torch and heat the bolt until it barely glows. I guarantee that it will come right off like butter.
Old Jun 30, 2002 | 05:53 PM
d357r0y's Avatar
this ***** ****** mother ****** is not coming off!!
impact = NO
pry bar = NO
torch = NO
suggestions?
Old Jun 30, 2002 | 06:14 PM
Hcivic88's Avatar
the torch wouldn't even do it???
all i had to do for mine was put some penetrating oil, hit it with a hammer a few times and i used a breaker bar, had to put all my weight into it, but it came loose.
i have no idea what to tell you, good luck though
Old Jun 30, 2002 | 06:29 PM
Carp's Avatar
New User
Here is what I did:
Went to sears, bought a long 1/2-socket extension so it would come out of the wheel well.
Also bought a 17 mm impact socket (any other socket will brake)
Got a 8 foot flag pole
Then I used a jack stand to support the socket extension that comes out of the wheel well, put the flagpole on the wrench, and then put everything I got into it.
I bent a craftsman 1/4" socket in half before I got the bolt off(it was holding the crank in place), but it came off.
Good luck!
Old Jun 30, 2002 | 09:20 PM
89 CRX SI's Avatar
have you got it off yet?
Old Jul 1, 2002 | 01:25 PM
d357r0y's Avatar
Default Re: HELP!!! i cant get the crank shaft bolt off! (89 CRX SI)
nope.. im bringing it to my pals shop tomorrow.. im gonna end up paying $ to get that fugger off
the thing that really sucks is, the only reason i have to do the timing belt is cause i put on a d16y8 head.. had i just been happy with my stock slow motor, i would still be driving! gosh darn it!
Old Jul 2, 2002 | 06:18 PM
d357r0y's Avatar
its off!!
Old Jul 2, 2002 | 07:27 PM
CRXTSEE's Avatar
great!
so... what was the trick that worked (so i know before I tackle mine)?
Old Jul 3, 2002 | 06:17 AM
d357r0y's Avatar
Default Re: HELP!!! i cant get the crank shaft bolt off! (CRXTSEE)
17mm socket + 2ft extension + 6ft breaker bar + guy to hold pulley still + 220 pound guy to put force on the breaker bar =
Old Jul 3, 2002 | 07:25 AM
Speed PHreak's Avatar
There should be a hole or 2 in the crank pulley. Find a bolt big enough to fit snug in one of those holes. Now take a chain, put you bolt through one of the links and into the crank pulley hole. Now run the chain up to your engine mount and loop it around, keep it tight. You should be able to keep the crank puller from moving this way. This also helps when torquing it back down.
I used a 20ft external attenna mast as a breaker bar one time......That was funny ****.
Old Jul 3, 2002 | 07:31 AM
Jeff 360's Avatar
Well bein' that I've beatin' 2 Si hatches and and ex coupe plus a hatch with mini me swap all with my D15 powered EF I wouldn't say that adding that Vtec is gonna make a big difference...these are all track races too
Deviant117
Feb 28, 2011 02:22 PM
civicdelsol33
14
Jun 8, 2008 01:41 PM
OutlawCL
Jun 2, 2007 06:45 PM
jared99
May 31, 2006 04:34 AM
urb
May 27, 2005 04:46 PM
