FS: 00 D16Y8 cylinder head, 96-98 ex 5 speed engine harness, p05 ecu, 92-95 a/c, stock intake, sprin
2000 civic ex D16Y8 cylinder head complete no valve cover - sold
99-00 civic ex automatic OBD2b complete uncut engine wiring harness - $100
Working p05 ECU taken from 92 civic cx 5-speed, untouched - sold
Magnaflow 2.5" high flow catalytic converter, practically new - sold
(used literally for a couple weeks, doesn't look used inside)
92-95 civic OEM intake assembly, complete with CX and DX/SI arms - $30
92-95 civic A/C compressor, lines, wiring and relays - $25
OBD2 integra engine harness, cut, missing plugs - $20
(good for misc. connectors, pins, or can be repaired)
92-00 civic 94-01 integra 13/16" brake master cylinder - sold
(OEM Honda, new)
96-00 civic ex spark plug wires, prestolite brand - $10
(will most likely fit any d series)
92-95 civic rear hatch interior pieces, black - $10
92-95 hatch support lift shocks, both good - sold
92-95 stock springs, from a 92 cx - $10
92-95 rear hatch weatherstrip, great shape - $5
92-95 driver side headlight, the light is fine but plastic bracket is missing tabs - $5
Honda MAP sensor - $5
4-wire O2 sensor from integra GSR - $5
OEM plastic battery cover - $5
92-95 front lower engine mount bracket with brand new rubber mount - $5
92-95 windshield washer reservoir - $5
OBD0 integra 240cc injectors - $5
D16Y8 plastic cam gear cover - sold
D16Y8 PS pump and alternator brackets - $free
Thanks for looking.
Modified by eastbay92cx at 6:20 PM 1/22/2008
(OEM Honda, new)
Thanks for looking.
