help me out real quick plz!!! ..
Old Dec 28, 2007 | 06:32 PM
integraNooB's Avatar
Default help me out real quick plz!!! ..
im doing a motor swap tomorrow im takin the motor out of my 91 ls and putting in a 92 teg motor in. do i need to swap out the ecu and the wire harnesses too? ?
Thnx
Old Dec 28, 2007 | 06:37 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: help me out real quick plz!!! .. (integraNooB)
nooooooooooooooooooooo
Old Dec 28, 2007 | 06:38 PM
thnx alot
Old Dec 28, 2007 | 07:23 PM
Mcdc2's Avatar
Default Re: help me out real quick plz!!! .. (DOHCgarage919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">nooooooooooooooooooooo</TD></TR></TABLE>
x54645113241
Old Dec 28, 2007 | 09:10 PM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraNooB &raquo;</TD></TR><TR><TD CLASS="quote">im doing a motor swap tomorrow im takin the motor out of my 91 ls and putting in a 92 teg motor in. do i need to swap out the ecu and the wire harnesses too? ?
Thnx</TD></TR></TABLE>
Im not sure how the others are saying no, because its unclear what motor you will be swapping in.
To clarify, you currently have a 91 with an LS and you will be swapping in a 92 LS or GSR?
If its a LS motor than it will be a straight swap.
It it is a GSR motor than you will ned the ECU and harness, or you can wire in the wires for vtec yourself.
Ali
Old Dec 28, 2007 | 09:31 PM
Default Re: help me out real quick plz!!! .. (PrinceAli132)
the GSR and Ls motors are different? i thought they where both b18's
Old Dec 28, 2007 | 09:34 PM
jordan_civic's Avatar
mostly the same but gsr has vtec ls doesnt. Also I dont know if ls has the secondary butterflies.
Old Dec 28, 2007 | 09:45 PM
Wow,you guys need to search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraNooB &raquo;</TD></TR><TR><TD CLASS="quote">the GSR and Ls motors are different? i thought they where both b18's</TD></TR></TABLE>
LS = B18B
GSR = B18C1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan_civic &raquo;</TD></TR><TR><TD CLASS="quote">mostly the same but gsr has vtec ls doesnt. Also I dont know if ls has the secondary butterflies.</TD></TR></TABLE>
Mostly the same? Are you kidding me
The crank (stroke) is smaller, the rods are longer, the compression is higher, the head is different, etc.
Ali
Old Dec 28, 2007 | 09:54 PM
Yeah I know it just didnt want to go into detail. For the ecu they are basically the same so the vtec and butterflies are the only differences.
correct me if Im wrong
Old Dec 28, 2007 | 09:59 PM
Default Re: help me out real quick plz!!! .. (jordan_civic)
Im not too familiar with ecu's and tunning and what not. But i would believe that the fuel maps will be different, higher redline.
Im sure im still leaving something out but whatever.
Ali
Old Dec 28, 2007 | 10:08 PM
yeah im not familiar with it either except for the redline.
Old Dec 28, 2007 | 11:11 PM
northemt88's Avatar
The maps and the red line and you also have that pesky little knock sensor to deal with , and i beleive that the vacums are slightly different and maybe the speed sensor???? but not sure on that,
Old Dec 28, 2007 | 11:34 PM
Default Re:
how do i tell if it is a GSR ? will it say on the block?
Old Dec 28, 2007 | 11:38 PM
Default Re: Re: (integraNooB)
you dont no what motor you have? wow, but in front of block it will say B18c1 if its gsr
Old Dec 28, 2007 | 11:51 PM
northemt88's Avatar
Default Re: Re: (DOHCgarage919)
it will either say b18c1 or b18a1
b18a1 will bolt and plug right in b18c1 will be a little more challenging
Old Dec 28, 2007 | 11:52 PM
nA_Gsr303's Avatar
Default Re: Re: (northemt88)
Wow Motor swap eh? And you dont know what motor ha
honda is so full of dumb *** ricers
Old Dec 29, 2007 | 08:32 AM
Default Re: Re: (nA_Gsr303)
yea i kno i dont kno much but im learning i havent been on the import scene long if u couldnt tell lol .....well thnx alot guys
Old Dec 29, 2007 | 08:50 AM
gsteg91's Avatar
well i gess u guys are not to familiar with the da and the db da isb18a1 db is b17c not a b18c
Old Dec 29, 2007 | 01:08 PM
g3integragsr's Avatar
* B A N N E D *
DA:
Ls, Gs, Rs motor : B18a1
Gsr Motors : B17's
DC/DB:
Ls, Gs, Rs motor : B18b1
Gsr motors: B18c1
there is a stamp midway up the Block on the far left side.....right were the block and the tranny mate, that stamp tells you the block code
Old Dec 29, 2007 | 10:03 PM
northemt88's Avatar
first off all you guys should do some research before you give advice.From 1990 to 1991 is pre obd 1992 to 1993 is obd1 so on that note you need a new ecu and jerry rig your harness.also the easiest thing to do is just transfer your distributor and your injectors and your done so that way you can run an obd1 motor as pre obd
Old Dec 31, 2007 | 11:58 AM
Default Re: (northemt88)
i didnt have to do a motor swap overall but i have to swap out the tranny
Old Dec 31, 2007 | 12:03 PM
DA_9's Avatar
Default Re: (integraNooB)
Wait, 91 integras are obd-0 and 92 and 93 integras are obd-1...isn't that true? Then ull need a obd-0 to obd-1 conversion kit and the obd-1 ecu or is that only if ur trying to run VTEC that you have to change the OBD?
killer_Bseries
Aug 4, 2008 11:50 PM
integracura
Oct 15, 2005 10:49 AM
kaj
Feb 21, 2004 04:53 PM
