New rotor and still a brake shake @ high MPHs 40+!?
Old Dec 28, 2007 | 03:41 PM
trooper0641's Avatar
Default New rotor and still a brake shake @ high MPHs 40+!?
I'm getting a brake shake only @ high MPHs, 40 and over. It seems to becoming from the right side.. so I replaced the rotor thinking it would solve the problem. It didn't. What else could it be? Your experiences and thoughts please.
i forgot to mention that it's my front passenger side brakes that is causing the brake shake. i also just swapped brakes from civic to integra. my civic's knuckle/brake setup wasnt causing a shake like this before untill i switched to the integras.
Modified by trooper0641 at 1:04 PM 12/29/2007
Old Dec 28, 2007 | 04:36 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: New rotor and still a brake shake @ high MPHs 40+!? (trooper0641)
Make sure the hub is free of corrosion before installing the rotors. Corrosion can cause rotor runout since the rotor cannot mount flush.
Old Dec 28, 2007 | 09:23 PM
MrDomino's Avatar
brake pads maybe
odishaw's Avatar
replace your ball joints..
Old Dec 28, 2007 | 09:45 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">I'm getting a brake shake only @ high MPHs, 40 and over. It seems to becoming from the right side.. so I replaced the rotor thinking it would solve the problem. It didn't. What else could it be? Your experiences and thoughts please. </TD></TR></TABLE>
it could be a bad
ball joint
axle
tie rod
blown shock...
spend some time under the fender and see if you see some parts that are really worn, start there.
also, the shaking, is it when you brake only or when you are driving? if it's when you drive then it has nothing to do with rotors and maybe more like a motor mount.
Old Dec 29, 2007 | 12:02 AM
red01teg's Avatar
Default Re: New rotor and still a brake shake @ high MPHs 40+!? (philosofy1)
ball joint or tie rod is my guess
Old Dec 29, 2007 | 12:12 AM
cwd14's Avatar
Default Re: New rotor and still a brake shake @ high MPHs 40+!? (red01teg)
All the things that have been said are possible but I usually like to try the super simple cheap crap first like going to a tire place and getting ur tires balanced. then after that go on to the expensive crap.
but I guess if it was a tire balancing issue it would be shaking all the time but balancing your tires is so cheap it doesn't hurt to try it.
Old Dec 29, 2007 | 11:25 AM
Default Re: New rotor and still a brake shake @ high MPHs 40+!? (cwd14)
im getting the brake shake only when im braking @ higher mphs like 40 and over. can a bad upper/lower/steering rack's balljoint cause a brake shake like this? has anybody had any exp from this?
proudcss
Honda Civic (2001 - 2005)
Dec 27, 2007 07:42 AM
tjluvsahonda
Oct 4, 2007 08:09 AM
Fatcobra
Mar 27, 2007 11:45 AM
TrakDay
Oct 25, 2006 06:29 PM
