lca's which ones
Hey guys at h-t i have a simple easy question. I have a subframe brace "asr is the brand if you were wondering". I want to get lca's for it but which ones wicked, megan or blox also want to run a rear sway bar too what diamiter should i go with. So tell me what you think?! thanks
Jeff h
Jeff h
I'd stay away from LCAs with rubber bushings. Go with Skunk2, Omni Power (3rd Gen), or Function 7. They have the polyurethane bushings that won't wear out after a few months and they have the endlink holes in the factory position.
I personally went with an ITR 22mm rear sway bar. I would recommend any sway bar 19mm or larger. Depending if you have a factory front sway bar, I would go 22mm or larger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">So if u have Factory Front what size can u go up too</TD></TR></TABLE>
ASR makes a 32mm hollow sway bar. If you can get ahold of a Mugen 26mm... Cusco and ASR make 24mm sway bars.
a lil off topic..but i have seen cars around with painted lcas...does any have any pics on how they look up close?...and would you guys suggest doing this? thanks
I'm really sick of hearing this bullshit about rubber bushings.
I have Gen1 Omni-Powers (the most **** talked about ever) with the original "crappy" rubber bushings, and they are still fine. I've had them for like four years in the rain and snow ....
Still fine.
So get whatever ones you think look best.
Still fine.
Mikes2000civicsi
Mar 27, 2008 09:02 PM
