Aftermarket actuator
I got a Viper alarm that uses 2 wires for lock unlock green and blue wire. What I was wondering is could I hook up the wire straight to the actuators or do I need a relay.
As stated in the manual that accompanied your alarm, you will burn out the low-current lock/unlock output if you hook an aftermarket actuator directly.
You need relays. Preferably the 451m module that comes with most newer DEI alarms/starters.
i hooked the wires directly to my alarm... what are these low current what chu ma call itz that i will burn out??? mine has worked fine for 2 years. but of course it's half-azzzz'd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_joshchang_story »</TD></TR><TR><TD CLASS="quote">i hooked the wires directly to my alarm... what are these low current what chu ma call itz that i will burn out??? mine has worked fine for 2 years. but of course it's half-azzzz'd</TD></TR></TABLE>No you did not.
It will not work, the door lock outputs are low current, [200mA], it takes more then that to drive one actuator.
What you may have is an alarm with door lock relays built in, in which case you can connect the door lock actuators directly to the alarm, or your car already had power door locks, or the door locks you installed had relays, [central locking kit] in which case you only need low current door lock outputs from the alarm.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taltares »</TD></TR><TR><TD CLASS="quote">U need relays if u r using aftermarket acuators.</TD></TR></TABLE>
Hey thanks for answering the question that has been answered twice before. Without your input, I don't think he would have known what to do.
