Need help! OBD 0 no fuel pulse.
Old Dec 28, 2007 | 09:26 AM
JDM97EK's Avatar
Default Need help! OBD 0 no fuel pulse.
I am trying to help a guy out. He has a 1990 CRX Si. It has a jdm OBD 0 B16. He tryed to hook up a MSD ignition (used, none the less) and now no start. I took everything back off and had no spark or injector pulse. I found that he messed up the wiring inside the distributer pretty good. I replaced the distributer with an obd 0 ls integra distributer (cut an arm off the distributer). now have spark but very intermittent injector pulse. I replaced the EFI relay and ECU still nothing. He mentioned converting to OBD 1. But I think that wont help his problem. anyone have this same problem? any ideas? Fuel pressure is 40 psi > good spark > compression 195 psi.
Old Dec 28, 2007 | 12:40 PM
JDM97EK's Avatar
Default Re: Need help! OBD 0 no fuel pulse. (JDM97EK)
any ideas out there?
Old Dec 28, 2007 | 12:51 PM
black0hatch's Avatar
he must have messed up the wireing somewhere. try known good injectors.
Old Dec 28, 2007 | 01:50 PM
B16CRXT's Avatar
check his "alternator solenoid" fuse under the dash.
Old Jan 1, 2008 | 06:51 PM
JDM97EK's Avatar
Default Re: Need help! OBD 0 no fuel pulse. (B16CRXT)
All fuses are good and the injectors are fine as well. There is no power from the ecu to the injectors. I know this because I have a noid light hooked up to it and it is not flashing. Any one else with some ideas?
Old Jan 2, 2008 | 09:16 AM
alscrx's Avatar
Possible he fried the ecu with his bad wiring on the msd box. Check with a good known pr3 or pw0
If all fuses are good check the resistor box for injectors
Old Jan 3, 2008 | 05:26 PM
B16CRXT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97EK &raquo;</TD></TR><TR><TD CLASS="quote">All fuses are good and the injectors are fine as well. There is no power from the ecu to the injectors. I know this because I have a noid light hooked up to it and it is not flashing. Any one else with some ideas?</TD></TR></TABLE>
does the ecu cycle and fuel pump rime when the key is turned "on"?
lifethinker
Apr 21, 2014 01:04 PM
B16Civic93
Jan 20, 2014 04:30 PM
k20superchargedtuboitbs
Jan 31, 2011 07:44 AM
blaxican05
Jul 2, 2006 02:09 PM
EGHatchy
Jul 14, 2002 11:25 AM
