Pic Request: Perfectly straight radius rods...
Can someone post a picture of a perfectly straight radius rod, front lower control arm, and the bolt holes of the front crossmember? I just picked up those parts from a junkyard and I need something to compare them too. I would hate to install bent parts. Thanks
you should be able to tell if something is bent by just looking at it. and it would have marks on it like if it got hit. if i had a camera i would help you out but i dont.
Dare...are you serious?
Look at them...you'll be able to tell.
Or if you happen to roll by the shop, we've got precision measuring devices we can use that will tell you what's bent if it doesn't line up right... You know my shop is pretty much at your hands...
io<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch »</TD></TR><TR><TD CLASS="quote">you should be able to tell if something is bent by just looking at it. and it would have marks on it like if it got hit. if i had a camera i would help you out but i dont.</TD></TR></TABLE>
That not always the case.
Thanks anyways
Thanks anyways
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR »</TD></TR><TR><TD CLASS="quote">Dare...are you serious?
Or if you happen to roll by the shop, we've got precision measuring devices we can use that will tell you what's bent if it doesn't line up right... You know my shop is pretty much at your hands...</TD></TR></TABLE>
Cool
I'm a call you
Cool
I'm a call you
That and/or I've got the front cross member and tie rod arms pulled out of the project hatch up here...and you're more than welcome to borrow it or compare or whatever. I won't need it for a little while...
