F/s.F/t 1995 ex 5lug,ctr,bc4,clean,black
Old Dec 27, 2007 | 11:38 PM
Usdmowns's Avatar
Default F/s.F/t 1995 ex coupe 5lug,ctr,buddy club cams, built b16,black
B16a with ctr pistons 5,000 miles
Civic Type R LSD transmission
36mm axles
Place Racing motor mounts
Exedy Organic clutch disk
Exedy Pressure plate
ACT XACT 8.8lb flywheel
ARP flywheel bolts
arp head studs
mugen head gasket.12:2:1 c/r
Spoon Magnetic oil drain plug
Rocket Motorsports Generation 2 dual valve springs
Rocket Motorsports Titanium retainers
New OEM honda valve seals(200 miles ago)
Peak Performance adjustable cam gears with upgraded bolts
Peak Performance intake manifold gasket spacer
F1 SPEC Tri-Y stainless header(identical to HyTech production)
STR cam seal plug
MSD Super Conductor plug wires
ngk iriduim plug(new)
Buddy Club Spec 4 cams
Port matched Civic Type R intake manifold
JG Edelbrock 65mm throttle body
3" AEM intake
3" inlet Velocity Stack
Fluidyne aluminum radiator and fan, with Fluidyne Radiator Cap
RC 310cc injectors
ITR throttle Cable
Omni Power 2.5" test pipe
Greddy Evo2, 2.5" full Exhaust
new from Honda Distributor
Momo Monte Carlo steering wheel(350mm)
Momo Extended hub
Heel-Toe Auto pedals
JDM EG6 clock
Amber gauge cluster with green needles
Civic Type R floor mats, black
B&M single bend short shifter
Whiteline shifter bushings
Civic Type R shift ****
Car is partially dyno tuned on Crome by Josh Bonati(Raceline, will probably be fully tuned by time of sale,
Pherable.Net Socketed P06 ECU with Lexan cover
5 lug front and rear hubs
11.1" Front Brembo blank rotors
10.3" Rear Brembo Blank rotors
front and rear ITR calipers
Axis Metal Master front brake pads
Project Mu rear brake pads
MOTUL Dot 4 brake fluid
ITR rear trailing arm assemblies
JDM ITR rear Lower control arms
Whiteline suspension bushing kit(not complete)
Integra Type R master Cylinder
Omni Power front upper control arms, camber kit
Omni Power rear upper control arms
Omni Power ITR spec 12k/10k full coilovers
Civic Type R front sway bar
megan rear lower tie bar
Wings West ABS front lip
Smoked Amber Vision replica Corners
White Civic Type R wheels(5x114.3, 15x6")
Dunlop 205/50/15 tires
Zenki Extended titanium lug nuts
pioneer MP3/CD player Head unit (with remote)
Eclipse rear 6x9's
Eclipse door speakers
dc2 seats.
mint interioor
power evertyhing(everything works
tucked and painted bay.
car is 12 years old dings and scrapes. NO RUST!
when I was doing the tuck and motor work
I want to get back into crx's only 90-91's plus cash on your part
but throw out offers.
cars i wont trade for..
eg 4-doors-
eg coupes
240's
ford/chevy's
only hondas maybe others just show me what you got.
Modified by Usdmowns at 3:57 AM 12/28/2007
Modified by Usdmowns at 4:22 AM 12/30/2007
Old Dec 28, 2007 | 12:00 AM
mannyman2's Avatar
Default Re: F/s.F/t 1995 ex coupe 5lug,ctr,buddy club cams, built b16,black (Usdmowns)
nice engine bay. reminds me of my old crx
Old Dec 29, 2007 | 12:05 AM
Usdmowns's Avatar
5 LUG
Old Dec 30, 2007 | 12:22 AM
Usdmowns's Avatar
200 whp 1.6
Old Dec 30, 2007 | 07:38 PM
Usdmowns's Avatar
offers?
Old Jan 2, 2008 | 03:00 AM
Usdmowns's Avatar
snow! in ohio
n20andy
May 19, 2009 10:38 PM
1greatEG
Jul 14, 2007 04:08 PM
JadeGreenEF9
Jun 27, 2007 11:06 PM
neo_
23
Aug 9, 2006 10:01 PM
brnyrdcmndo
Jul 27, 2004 11:05 AM
