Does the 90-97 Accord Hub Removal Tool Work on Other Honda's?
Just as the title states, Does the 1990-1997 hub removal tools work on other honda's? I own a shop and want to know if the tool works to remove hubs on other cars like the prelude and civic so that you can replace studs when they get stripped/break, if so i think it would be a wise investment otherwise i will stick to my good old slide hammer.
Thanks
Thanks
I never understood the hub removal tool. Thats the one that pushes on the axle right?
Anyway, chances of a tool made for the 90-97 Accord front hubs working on a Civic or Integra probably isn't good.
If you own a shop, it would be best to invest in a press. That way you can easily remove hubs/bearings/etc. A press would be a much wiser investment that will work on various other vehicles.
the Matco tool is good for only 90-97 Accords, and 97-00 Acura CL's.
those are the only ones that have the 14mm bolts between the studs.
LOLO93PRELUDE
Jun 26, 2008 03:09 PM
jdm-hondacura
Nov 17, 2006 05:24 PM
wagonboss
Feb 2, 2004 11:54 AM
