oil leak....
Old Dec 27, 2007 | 08:09 PM
96electronH's Avatar
Default oil leak....
i have an oil leak on my 96 ex and im 99% sure its all coming from the vavle cover since i painted it and replaced the gasket. But i oe tightened two of the bolts ...and now i dont think its sealing right is my only option to re-tap the threads and new bolts or is there something else?
Old Dec 27, 2007 | 08:15 PM
HAPRECYCLING's Avatar
Did you break off 2 bolts for your valve cover? Not sure what "i oe tightened two of the bolts" means?
Did you use any HondaBond?
Old Dec 27, 2007 | 08:23 PM
over tightened them and now when i tighten it to a point it kinda jumps of the thread and is loose again...and no hondabond?
Old Dec 27, 2007 | 08:29 PM
It does not need to be super tight. Slipping of the threads? Use should use some hondabond or some sort os gasket sealer. This will help.
Old Dec 27, 2007 | 08:31 PM
like rtv silicone i was thinking about laying the **** on there thick and that may work
Old Dec 27, 2007 | 08:40 PM
Not to thick. You dont need much, a lil more on the corners tho.
Old Dec 27, 2007 | 08:45 PM
thanks for the help hopefully it fixes the leak and since its leaking im gonna use the seafoam to clean the engine bay..do you know if seafoam will pull the paint off my valve cover?
Old Dec 27, 2007 | 08:47 PM
Not sure never used seafoam. i use Simple green. or this other stuff called red hot. It's like simple green on steroids.
Old Dec 27, 2007 | 08:52 PM
where did you get "red hot"?
Old Dec 27, 2007 | 09:53 PM
I think its only in california. I get it off this guy who has his own little commercial cleaning products. From glass cleaners and waxes, and this wash n wax soap that smells like cherries! His stuff is amazing. its called carbrite
moparguy
Sep 9, 2015 03:57 PM
94 IntegraLS
Sep 20, 2013 06:54 AM
kingofnothing
Jan 8, 2008 11:06 AM
smores
Jul 4, 2005 06:52 PM
ysrhatch
Sep 12, 2001 01:30 PM
