Suspension & Brakes Theory, alignment, spring rates....
trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
Old Dec 27, 2007 | 07:10 PM
Tuner Eddy's Avatar
Default trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
Alright fella's, I ordered my ASR 24mm sway bar from weaksauce a few weeks back and decided to put it on tonight. I noticed while trying to line the holes up with the "D" brackets that the holes for the bolts were covered by the bracket when one bolt would go in.
To try and make better sense of it, only one bolt on each side of the D bracket would line up, and the other hole would be covered by the bracket.
This frustrates me, because i remember asking Weaksauce on the phone if the ASR sway bar would work with my Carbing rear lower tie bar, and they were firm with their assurance that it would work.
So I am asking, do I need to have the ASR subframe brace in order to run the sway bar?
Old Dec 27, 2007 | 07:25 PM
Targa250R's Avatar
be professional
Default Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (Tuner Eddy)
How far off is it? A photo would help.
Old Dec 27, 2007 | 07:28 PM
Tuner Eddy's Avatar
Default Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">How far off is it? A photo would help.</TD></TR></TABLE>
about a solid 1/4".
Pretty much, there are 4 main bolts (2 on each side) of the sway bar that go into the D brackets. I can only line up the top two, or the bottom two.
Old Dec 27, 2007 | 07:40 PM
Targa250R's Avatar
be professional
Is it possible for you to get different brackets/bushings?
Old Dec 27, 2007 | 09:55 PM
.:Made in OC:.'s Avatar
You will have to run the carbing low tie bar on top of the asr brace if thats what your wondering.
Old Dec 28, 2007 | 04:50 AM
Tuner Eddy's Avatar
Default Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (.:Made in OC:.)
so do i need to take the tie bar off? because it didnt seem to be in the way at all.
no, i am wondering if i need the ASR subframe brace to run the sway bar....i do not have it.
Old Dec 28, 2007 | 06:56 AM
Tuner Eddy's Avatar
ttt
Old Dec 28, 2007 | 08:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
So you bought the sway bar, but not the brace? How are you mounting it to the subframe.
96-00 Civic subframes are known to be somewhat weaker than 92-95 Civics and 94-01 Integras. I would highly suggest the ASR brace, which should make it a complete bolt-on affair and no worries of subframe tear-out.
Old Dec 28, 2007 | 08:48 AM
weaksauce.org's Avatar
Default Re: (PatrickGSR94)
Pmd!
** You actually need the ASR brace itself to mount their new 24mm setup. I believe there was some miscommunication regarding which brace you have.
Modified by weaksauce.org at 10:47 AM 12/28/2007
Old Dec 28, 2007 | 09:40 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuner Eddy &raquo;</TD></TR><TR><TD CLASS="quote">I am wondering if I need the ASR subframe brace to run the sway bar....I do not have it.</TD></TR></TABLE>
YES...and when you get the subframe brace you will be instructed to drill a new hole for the bolt that goes into the D bracket.
Old Dec 28, 2007 | 11:31 AM
Tuner Eddy's Avatar
Default Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">
YES...and when you get the subframe brace you will be instructed to drill a new hole for the bolt that goes into the D bracket. </TD></TR></TABLE>
that sucks, i didnt know i'd have to do any drilling.
it will be fine to run my stock lower control arms with this setup correct?
Old Dec 28, 2007 | 12:41 PM
Community Builder
I wouldn't think it would interfere with your LCA's at all.
Old Dec 28, 2007 | 01:35 PM
Drilling? On which part? Pmd.
Tholliday
Honda CR-V & Element
Oct 31, 2018 03:03 PM
JiNxXx0013
Suspension & Brakes
Sep 16, 2017 07:26 PM
exist12
Nov 29, 2009 10:52 PM
Tuner Eddy
Dec 28, 2007 04:59 PM
DJLikwid
May 15, 2007 07:46 AM
