Da idling really bad (really low)
Old Dec 27, 2007 | 06:41 PM
underb00steg6's Avatar
Default Da idling really bad (really low)
any input on my idling problem....my da is idling really really low change spark plugs, spark plugs wires, no cel lights....any suggestions on checking? ......and by the way i did a search....any help? ...thanks
Old Dec 27, 2007 | 07:11 PM
Crx Jimmy's Avatar
Default Re: Da idling really bad (underb00steg6)
clean the throttle body plate and IACV. check the timing, if all are ok just adjust the idle screw
Old Dec 27, 2007 | 07:23 PM
Default Re: Da idling really bad (Crx Jimmy)
ill give that a try ....anybody else?
Old Dec 27, 2007 | 08:01 PM
jhammond_82's Avatar
Reject Papi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">clean the throttle body plate and IACV. check the timing, if all are ok just adjust the idle screw</TD></TR></TABLE>
Old Dec 27, 2007 | 09:59 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 &raquo;</TD></TR><TR><TD CLASS="quote">ill give that a try ....anybody else?</TD></TR></TABLE>
check your vacuum lines for leaks
Old Dec 28, 2007 | 07:30 PM
Default Re: Da idling really bad (Lord Helmet)
thanks ill give all of those a try .......
Old Dec 29, 2007 | 03:56 PM
anybody else??
Old Dec 29, 2007 | 07:39 PM
ttt....anybody else?
Old Dec 31, 2007 | 12:04 PM
anybody else?
Old Dec 31, 2007 | 12:08 PM
DA_9's Avatar
If your car boggs like its running out of gas when u hit your throttle replace your fuel filter if not that do everything that previous people have told you.
Old Dec 31, 2007 | 07:38 PM
Default Re: Da idling really bad (DA_9)
thanks i keep that in mind
Old Jan 1, 2008 | 12:58 AM
eg6d15's Avatar
timing off?
Old Jan 1, 2008 | 04:10 PM
Default Re: Da idling really bad (eg6d15)
yeah i just did it over and im sure i did it right .....i guess ill have to double check it out......sucks!.....
Old Jan 3, 2008 | 06:06 PM
ttt!
Old Jan 4, 2008 | 06:57 PM
up
Old Jan 9, 2008 | 05:28 PM
ttt
Old Jan 9, 2008 | 06:34 PM
denraweb's Avatar
Did you check all the mentioned above? Or are you just gathering as much enough as possible?
Old Jan 9, 2008 | 08:31 PM
Default Re: Da idling really bad (denraweb)
i did check all of the above....just trying to find more if i missed anything else
98jdmek
May 20, 2007 12:04 PM
dc4g
Nov 24, 2005 10:04 AM
1990 CRX Si
Nov 15, 2005 12:09 PM
jdmCivic925
Oct 25, 2005 02:37 PM
oddball327
Apr 25, 2005 01:14 AM
