Speedo not working, replaced VSS plug already
Old Dec 27, 2007 | 04:35 PM
so simple's Avatar
Default Speedo not working, replaced VSS plug already
So my 95 GSR the speedo started to randomly stop working last month or so, but sometimes it would cut back on after a couple minutes. At the same time, I changed my thermostat, after that, my speedo died and never came back on. Im thinking the coolant from the thermostat change completely did in the VSS connector, so I tried cleaning it with terminal cleaner spray, no luck. Swapped out with a new (used) VSS plug today, the odometer works now but still no speedo. WHen i stripped the wires to solder on the new plug, i noticed the wiring seemed a bit corroded. Could it be the wires just corroded all the way thru? or should i just change out the VSS sensor?
Thanks
Old Dec 27, 2007 | 04:41 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Speedo not working, replaced VSS plug already (so simple)
Since the odometer works, the fault is most likely in the speedometer.
Old Dec 27, 2007 | 04:46 PM
so simple's Avatar
my cruise control also still doesnt work, i read that if cruise doesnt work its the vss. or does the cluster have something to do with cruise also?
also, by your theory, it means i coincidentally had a problem with both vss and cluster?
Old Dec 27, 2007 | 05:12 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (so simple)
Does VTEC work?
Old Dec 27, 2007 | 06:19 PM
so simple's Avatar
car is turbo so i cant really tell if vtec is working? dont know if thats stupid or not..
anyways, problem fixed. i took off the 2 10mm bolts and removed the top portion of the vss, when i pulled it off, a cloud of dust/powder/corrosion puffed out. i cleaned off the contacts closer this time as before i only just sprayed some cleaner down on it before it was removed. i also noticed the middle pin was slightly loose, probably gonna break off one day. anyways, speedo seems to be working now so i guess there was just corrosion on the inside of the top portion of the vss.
thanks though
Old Jan 17, 2008 | 01:28 PM
FSS13foxtrot's Avatar
will vtec not work if the vss isnt working properly?
Old Jan 17, 2008 | 02:03 PM
polishedturd's Avatar
I like PIE
Default Re: (FSS13foxtrot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FSS13foxtrot &raquo;</TD></TR><TR><TD CLASS="quote">will vtec not work if the vss isnt working properly?</TD></TR></TABLE>
no it wont
Shran29
Jun 10, 2012 03:58 PM
Mr.Death
Sep 15, 2007 09:45 PM
ek4h
Apr 15, 2007 07:49 PM
frostcivic
May 30, 2006 09:35 PM
plusONE DC2
20
Aug 17, 2004 07:47 PM
