Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
this is BS!
Old Dec 27, 2007 | 04:12 PM
killyourscene's Avatar
Default this is BS!
I took my car into honda today to see whats the deal with my 3rd gear notchy, grind problem that alot of people have. After them checking it out they said it was because I went from 6th to second and over revved! I don't remember me ever doing that.
They said because of this computer proof of me doing it they cannot cover it under warrant and that if i want it fixed it's going to be $1008. I told them I had proof of other si's who have this problem on honda tech. They said the proof I have is un valid because of me supposedly going from 6th to 2nd.
So I guess for the next 5 years I'm going to have to drive my si nice and cautous when i shift into 3rd. pshhh
Old Dec 27, 2007 | 04:26 PM
lostjap89's Avatar
Default Re: this is BS! (killyourscene)
thats what im scared of because now that its cold the notchyness is even worse so im going in this weekend for a rattle in my window and see what they can do about the third gear. hopefully they dont try and blam it on driver error cause its been there since i got the car. Ive taken it in once before and they said the problem wasnt there so well c what happens.
Old Dec 27, 2007 | 04:30 PM
cnyej1's Avatar
Default Re: this is BS! (lostjap89)
If you over-revved it would have hit the limiter which is something you would have remembered. So did you? Tell the dealer you want a print out of the scan from the ecu. If they deny you get on the phone with Honda and tell them the situation.
Old Dec 27, 2007 | 04:40 PM
RICO_'s Avatar
NO MERCY!
So WTF is wrong with your car? Is it your gears....your tranny....what! Or did they just make up some bullshit lie to con you out of money?
I didn't know the computer can read gear changes and when they occur....I thought it only back tracks RPM rev ranges.
Old Dec 27, 2007 | 04:50 PM
fg2si!kid's Avatar
New User
Default Re: this is BS! (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">
I didn't know the computer can read gear changes and when they occur....I thought it only back tracks RPM rev ranges.</TD></TR></TABLE>
i would question that iam not a honda tech but i dont think there is any sensors in our tranny that can do that sounds like something BMW would do not honda i call a BS on the dealer
Old Dec 27, 2007 | 04:58 PM
aeenox's Avatar
damn thats a burn...man i just got my car picked up by a tow truck cause my tranny is messed up hopefully they dont try to bs me too
Old Dec 27, 2007 | 04:59 PM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">So WTF is wrong with your car? Is it your gears....your tranny....what! Or did they just make up some bullshit lie to con you out of money?
Im not exactly sure how they do it.....but, say the revs are recorded at 8k rpms and then the revs drop to 6k rpms and the speed is increased rather than a decrease caused by a lift of the throttle. Im sure that would denote a shift. Does that make sense? Im trying my best here to explain it.
Old Dec 27, 2007 | 05:10 PM
RICO_'s Avatar
NO MERCY!
Default Re: this is BS! (cnyej1)
I say get a print out or have them show you the results and POINT OUT exactly where the so-called mis-shift happened. If they try to bullshit you further after that....not wanting to show you the printout.....then go to corporate. They need to be able to PROVE you screwed up. And if they can prove it then they should have no problem showing you the proof. Not just make a blind claim just to try to squeeze money out of you.
Old Dec 27, 2007 | 05:31 PM
fg2si!kid's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">
Im not exactly sure how they do it.....but, say the revs are recorded at 8k rpms and then the revs drop to 6k rpms and the speed is increased rather than a decrease caused by a lift of the throttle. Im sure that would denote a shift. Does that make sense? Im trying my best here to explain it. </TD></TR></TABLE>
ok i see what yor trying to say makes sense
Old Dec 27, 2007 | 06:01 PM
HA0LEFIED's Avatar
i thought only evo's and sti's have computer reads of changes?
Old Dec 27, 2007 | 06:40 PM
cnyej1's Avatar
Default Re: (HA0LEFIED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HA0LEFIED &raquo;</TD></TR><TR><TD CLASS="quote">i thought only evo's and sti's have computer reads of changes?</TD></TR></TABLE>
Id say most new cars have this ability.
Old Dec 27, 2007 | 07:20 PM
Default Re: (cnyej1)
I got copies of the test they ran..and it shows that I did shift from 6ht to second and it revved to 9085 RPMS. But I didn't say anything about my 2nd or 6th acting up, just my third. It just doesn't make any sense to me how my 3rd gear is notchy cause of something i did in 2nd gear. I honestley dont remember that to begin with. They're just using that as an excuse to not fix anything on my tranny.
Old Dec 27, 2007 | 07:33 PM
lostjap89's Avatar
Default Re: (killyourscene)
how long do the logs record for because i miss shifted a while back and i dont want it to show up
Old Dec 27, 2007 | 07:42 PM
HA0LEFIED's Avatar
seriously.... this new tech sucks big donkey.
Old Dec 27, 2007 | 11:03 PM
ricedallas's Avatar
Default Re: (lostjap89)
honelsty how do you go from 6th gear to second, is what i would like to know, you sound like u screwed yourself here by not knowing how to drive
Old Dec 28, 2007 | 02:36 AM
RICO_'s Avatar
NO MERCY!
Default Re: (ricedallas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricedallas &raquo;</TD></TR><TR><TD CLASS="quote">honelsty how do you go from 6th gear to second, is what i would like to know, you sound like u screwed yourself here by not knowing how to drive</TD></TR></TABLE>
It's easier than you think actually. Most people aren't aware how close these gears are to each other so it's certainly possible.
Although the point still stands....people have been having this 3rd gear issue for a long time now. OP try changing your tranny fluid to the new Honda MTF if you haven't already.
Old Dec 28, 2007 | 03:31 AM
IT GUY's Avatar
Default Re: (RICO_)
6th and 2nd are next to each other, no reason you should be going towards 2nd or even 4th from 6th .... 6th to 3rd is understandable, at least it's in the right direction.
what the dealer said is BS unless they can show you on the datalog printout where you overrevved on a missed shift.
Old Dec 28, 2007 | 04:21 AM
Vero's Avatar
I'm still confused as to how reving the engine is going to harm the transmission... or how going from 6th gear to 2nd will hurt 3rd.
They all sound unrelated.
Old Dec 28, 2007 | 04:36 AM
k20roadrage's Avatar
Default Re: (Vero)
I took my FA to the stealership for the same issue. They claimed nothing was wrong and it didn't need to be fixed. I'm almost afraid to ask them about it again because of what you just told me. I'd like to think my dealership wouldn't screw me like that if something does go wrong but you never know.
Does anyone know what it takes for Honda to release a recall for this issue. Something tells me a dealership won't even touch this issue without one.
Good luck bro!
Old Dec 28, 2007 | 04:43 AM
Type X's Avatar
Default Re: (k20roadrage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20roadrage &raquo;</TD></TR><TR><TD CLASS="quote">
Good luck bro!</TD></TR></TABLE>
about 3-4yrs
http://tl.acurazine.com/forums...53377
Old Dec 28, 2007 | 06:19 AM
cnyej1's Avatar
Default Re: (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">
They showed him the printout he said.
Old Dec 28, 2007 | 06:28 AM
IT GUY's Avatar
sorry.. missed that
Old Dec 28, 2007 | 06:44 AM
97Ej6's Avatar
Scan the print out (for us to see what they see), and it does sound like you just screwed yourself over tho.
I'm thinking like you tho, what does shifting to second have to do with 3rd...
Old Dec 28, 2007 | 06:47 AM
IT GUY's Avatar
Default Re: (97Ej6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6 &raquo;</TD></TR><TR><TD CLASS="quote">Scan the print out (for us to see what they see</TD></TR></TABLE>
X2
I'd like to see that. I'd also like to know how they determine what gear you're in?
Old Dec 28, 2007 | 07:17 AM
cnyej1's Avatar
X2
I'd like to see that. I'd also like to know how they determine what gear you're in?</TD></TR></TABLE>
It can be determined by the speed of the car and what RPM the engine is at. If you have both of those it can be figured out.
