h22 into EG parts list check
Old Dec 27, 2007 | 01:23 PM
lilsizfly's Avatar
Default h22 into EG parts list check
h22a1 with tranny
What ECU?
Use and modify EG wiring harness?
Which mounts Hasport or HCP?
Which Driver side axle?
Which Passenger side axle?
Which shift linkage?
Which shifter assembly?
Resistor box or no?
Am i missing anything?
I have only made this because after reading the first 15 pages of the sticky gave me a headache Plus ive heard various things going wrong (vibration, wrong axles, etc.)
Old Dec 27, 2007 | 05:05 PM
sleepyH22's Avatar
Default Re: h22 into EG parts list check (lilsizfly)
p13 OBD 1 ECU
92-95 EX engine harness ( u splice in the injector harness and remove ALL THE YELLOW/BLACK WIRES and run the all into the one red wire on the resistor box. Then the 4 black wires coming out of the box goes one to each injector)
Also enlengthen starter and alt wires
89 integra Drivers side, prelude inner cup/joint
90 teg pass side w/ prelude inner cup/joint
use a 92-96 Prelude Halfshaft
shift cables and shift assembly from a 92-96 prelude
i did my h22 swap and love it, no problems whatsoever...i did the COMPLETE SWAP MYSLEF....
cmracing
Jul 19, 2008 03:41 PM
djroven
Feb 21, 2007 02:07 PM
SoCalWrencher
Jun 25, 2005 04:25 PM
F120man
Jul 8, 2003 01:22 PM
ItzTw
Feb 6, 2003 06:05 AM
