I NEED URGENT HELP! Please, I need answers.
Old Dec 27, 2007 | 10:36 AM
Razr2's Avatar
Default I NEED URGENT HELP! Please, I need answers.
I just my HIDS in today and I'm trying to install them..
I got everything else plugged in correctly but I can't plug the HIDS into my OEM harness.
This is the harness..
This is what I have to work with..
How do I do this? any help appreciated.
Old Dec 27, 2007 | 10:39 AM
Jussstin's Avatar
Default Re: I NEED URGENT HELP! Please, I need answers. (Razr2)
i had to do the same thing. You have to use the stock harness. The two prongs go to low beam and one goes to ground on the harness. I think the top of the plug is ground, and the left side of the plug is low beam. I think i see another ground which you do not have to connect to work.
Old Dec 27, 2007 | 10:43 AM
Razr2's Avatar
Default Re: I NEED URGENT HELP! Please, I need answers. (Jussstin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jussstin &raquo;</TD></TR><TR><TD CLASS="quote">i had to do the same thing. You have to use the stock harness. The two prongs go to low beam and one goes to ground on the harness. I think the top of the plug is ground, and the left side of the plug is low beam. I think i see another ground which you do not have to connect to work.</TD></TR></TABLE>
well how do I know which one goes on each side? Also how do I hook up the ground? Do I just stick it in there? cuz it stays loose when I do that.
Old Dec 27, 2007 | 10:52 AM
Jussstin's Avatar
Old Dec 27, 2007 | 11:02 AM
Malakai's Avatar
Wow thats a bunk looking wiring kit....
Old Dec 27, 2007 | 11:04 AM
Razr2's Avatar
Default Re: (Malakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">Wow thats a bunk looking wiring kit....</TD></TR></TABLE>
huh?
Old Dec 27, 2007 | 11:05 AM
Jussstin's Avatar
it just deletes the high beam option for H4 kits. Its pretty easy but it is sorta bunk.
vtecjunkiie631
Jan 2, 2024 04:58 PM
$MIKE$
Jun 12, 2014 02:04 PM
hylaxrng
Lighting
Oct 8, 2012 03:15 PM
chrisfromsrq
Feb 7, 2010 06:03 PM
nicehatchy
Mar 18, 2005 10:37 PM
