brake upgrade
Old Dec 27, 2007 | 08:43 AM
onemore's Avatar
Default brake upgrade
Before anyone say's it I searched. I just want to make sure before I hit up the junkyard.
I have a 89 crx HF will my knuckle work with the Johnathan mod?
I think I'm just going to go with the da knuckle swap front and back, dies it matter if th da I get the parts off of has abs?
Thanks.
Old Dec 27, 2007 | 09:35 AM
CRX Toad's Avatar
Default Re: brake upgrade (onemore)
Well you should really get either CRX or CRX Si Knuckles or 88-91 Civic DX/Si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onemore &raquo;</TD></TR><TR><TD CLASS="quote">
Also, there is no knuckle in the back it is a trailing arm. The 90-93 Integra front knuckle and rear trailing arms would be a good upgrade. Doesn't matter ABS or non ABS.
Old Dec 27, 2007 | 11:44 AM
onemore's Avatar
thank you toad, I dont now why I said knuckle in the rear. I read alot of your post's when I was searching the different brake setups you have been very helpfull. Thanks
svtford4x4
Aug 30, 2012 10:29 AM
phoenix_iii
32
Dec 11, 2011 07:40 AM
92civicfreak
54
May 26, 2007 09:03 AM
CRX EF 88
17
Mar 25, 2007 04:54 PM
dmbmalaka
Dec 2, 2004 10:32 AM
