Skunk2 Cam Gears Noise Question
Old Dec 27, 2007 | 07:17 AM
b20sedan's Avatar
B20 Bhai M.B.B.S
Default Skunk2 Cam Gears Noise Question
I just had a set of Skunk2 adjustable cam gears installed over the weekend on my nonVTEC B20Z w/Crower 403's (the cams were already in there for almost a year now). And I had a questions about them…has anyone else noticed that they are relatively loud and noisy at start up? They quiet down after about ten or fifteen minutes, once the engine warms up.
Just want to see if this is typical. Also, they are the “regular” series gears (blue), not the pro series.
Thanks!
Old Dec 27, 2007 | 10:56 AM
b20sedan's Avatar
B20 Bhai M.B.B.S
Default Re: Skunk2 Cam Gears Noise Question (b20sedan)
anyone?
Old Dec 27, 2007 | 11:50 AM
Runnerdown's Avatar
the gears don't make noise, but a tight timing belt will make a low pitch humming sound.
Old Dec 27, 2007 | 12:29 PM
b20sedan's Avatar
B20 Bhai M.B.B.S
Default Re: Skunk2 Cam Gears Noise Question (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">the gears don't make noise, but a tight timing belt will make a low pitch humming sound.</TD></TR></TABLE>
This doesn’t seem like the timing belt, it’s certainly not a low pitch hum…
Old Dec 28, 2007 | 03:41 PM
b20sedan's Avatar
B20 Bhai M.B.B.S
anyone else...
Old Dec 28, 2007 | 05:30 PM
92TypeR's Avatar
FSAE
I have never heard a cam gear, aftermarket or OEM, make any noise.
Recheck belt tension and torque on the cam gear allens, should be 7 lb-ft.
EKJOE
May 16, 2009 09:14 AM
WheaMyRyceGo
May 14, 2008 11:09 PM
doublejz
Nov 12, 2005 03:06 PM
Asahi
Dec 9, 2003 12:15 AM
The-LS
Apr 17, 2003 01:34 PM
