Front LCA's
So I was looking into buying a set of Front LCA's but I didn't really find to many options. I saw that omni makes a set. I wanted to post a thread on HT to see if I am overlooking and not seeing a company? I am open to anything Thanks in Advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">Omni seems to be the only company to make them.
Why do you want to replace your FLCA? I'm sure there are better things you could do with the cash, IMHO.
Ali</TD></TR></TABLE>
I am having issues with my stock ones so I figured I would just replace them since I replaced my rears also.
Just go to the junk yard and pick up another set.
The only real benefit I can see with aftermarket ones will be the weight savings but on a street car it will not be noticeable.
Granted they do say its been tested on 1000 hp drag cars and RR/Auto-X cars but this has me worried:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omni FLCA »</TD></TR><TR><TD CLASS="quote">Never use a hammer to release the ball joint from the FLCA, as this will damage the FLCA and may cause it to fail.</TD></TR></TABLE>
http://www.streetlevelperforma....aspx
http://www.omnipowerusa.com/product.asp?P_ID=135
So for a supposedly "quality" product that should be just as strong can not take a hit from a hammer
And for $400 i'd buy a used OEM piece instead.
Ali
And for $400 i'd buy a used OEM piece instead.Ali
