Suspension & Brakes Theory, alignment, spring rates....
How do you replace LCAs?
Old Dec 27, 2007 | 12:09 AM
slvrlude's Avatar
Default How do you replace LCAs?
I just bought some aftermarket rear LCAs and I wanted to know if they are as easy to replace as it looks. I have a 93 hatch w/ discs in the back. If anyone can do a quick write up or offer some tips, it would be nice.
Old Dec 27, 2007 | 07:44 AM
EK_B's Avatar
You might run into some seized bolts. But you basically undo the three bolts on the rear LCA and put the new ones in and put the bolts on.
Old Dec 27, 2007 | 08:30 AM
Targa250R's Avatar
be professional
Default Re: How do you replace LCAs? (slvrlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrlude &raquo;</TD></TR><TR><TD CLASS="quote">I just bought some aftermarket rear LCAs and I wanted to know if they are as easy to replace as it looks.</TD></TR></TABLE>
You would think so.
But since you're in the rust belt, be warned that the bolts may be seized into the inner bushing sleeves, which means they will break when you try to remove them - in which case it will be a major PITA if you don't have the correct tools (drill, torch, etc.).
As far as the procedure, it's pretty straightforward. Jack up the car, set on jackstands. Remove the rear wheels. If you have ABS, unbolt the wheel speed sensor wires from the control arms. If you have a rear sway bar, unbolt the end links. Remove the 3 bolts that hold the control arm (1 through the trailing arm, 1 through the damper, and 1 through the subframe). Install is reverse of removal. I'd suggest putting a light coat of anti-seize compound on the bolt shanks before you reinstall and torque them to spec.
You will probably want to have the car aligned after installing new control arms. It's not 100% necessary, but having the alignment checked is never a bad idea if it hasn't been done for a few years.
Good luck.
Old Dec 27, 2007 | 09:50 AM
Tyson's Avatar
Default Re: How do you replace LCAs? (Targa250R)
targa, you forgot that you need to preload the suspension while tightening the bolts in order to save the bushings. its in the helms.
Old Dec 27, 2007 | 01:31 PM
Targa250R's Avatar
be professional
Default Re: How do you replace LCAs? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">targa, you forgot that you need to preload the suspension while tightening the bolts in order to save the bushings. its in the helms.</TD></TR></TABLE>
Nothing is going to save the bushings in an aftermarket control arm
Old Dec 27, 2007 | 10:05 PM
slvrlude's Avatar
thanks for the help...i'm gonna start it tomorrow
Atomic1
14
Jun 4, 2011 03:41 PM
cheapskate
Suspension & Brakes
Apr 22, 2008 12:50 AM
ek9tl
14
Aug 22, 2007 03:12 PM
ek9tl
15
Jul 18, 2007 03:10 PM
Cliffjumper2
May 23, 2005 07:12 PM
