I would like to have some advice about brake rotor and caliper
Hello,
I would like to have your advice about brake caliper and brake rotor.
I'm using Civic ES with sw388 wheel sized 15" offeset +35 width 6.5" that I want to put Spoon's brake caliper in.
What model and size of brake rotor should I use?
Thank you.
Thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by proudcss »</TD></TR><TR><TD CLASS="quote">Hello,
Thank you.
What year/model is your car?
Thank you.
</TD></TR></TABLE>What year/model is your car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">
What year/model is your car?</TD></TR></TABLE>
Civic 2004 DX
Civic 2004 DX
Civic 2004 DX</TD></TR></TABLE>
Following this: https://honda-tech.com/zerothread/1765987
You could use the DC2/DB8 Calipers from here: http://spoonsports.us/catalog/...n.htm
There's a little more fudging than that to get the spoon ones on. The spoons arent floating assemblies, you cant grind a bracket on the caliper, you'd have to make yourself one.
You'd be better off with the Fastbrakes 11" Wilwood kit which would accomplish the same thing more or less... if it bugs you that much that they arent blue, I think wilwood will special order any color.
trooper0641
Dec 29, 2007 11:25 AM
