question on a blown motor....(but not sure need info)
Old Dec 26, 2007 | 08:41 PM
ja20_eg's Avatar
Default question on a blown motor....(but not sure need info)
would a blown motor compression still b all the same.... it sounds like a blown motor but not sure....
Old Dec 26, 2007 | 09:37 PM
Schister66's Avatar
Man U FTW
It depends on what's wrong with the engine. If you cracked a sleeve or ringland, then the compression is going to be 0 for that cylinder...the others may still be high. What do you think you blew?? Most times, there are smaller problems to blame...
Old Dec 26, 2007 | 09:54 PM
ja20_eg's Avatar
Default Re: (Schister66)
this guy sell it its a ls turbo but he never got it to run.. the only time it ran is when he got done builtting it...took it around the block n the starter pop out which he use only 1 bolt on the starter thats y it pop out. then he tow it home n put 2 bolt on it but one bolt was longer then the other one....then he started it up n sound like it blown....sopose he said might be that bolt that he put on that starter (that long one) that its hitting the flywheels that is making that nose......
Old Dec 26, 2007 | 09:59 PM
ja20_eg's Avatar
Default Re: (ja20_eg)
all 4 comperssion were 180 psi around there 175-185psi across
nitewolf
Oct 8, 2014 06:37 PM
Wrona
10
Dec 15, 2011 04:23 PM
90Integra
May 31, 2006 07:04 PM
hoehouseworker
May 15, 2005 06:57 PM
