gsr LSD?
in essence yes, i have seen both wheels spin before in the air but when you put it on the ground and do a burn out you should only see one tire mark, if there are 2 than you dont have a y80 or someone added lsd
that means that if one tires has ZERO traction, then that tire will spin while the other does not. if you have less than perfect traction, like snow, then one tires will spin greatly while the other might just a little. its tough to explain
its a shame only the ITR's came with LSD's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicexowner »</TD></TR><TR><TD CLASS="quote">so b16 tranny comes with lsd? i kinda get what you guys are saying. so b16 trannys are bad for boost? cause im boosting soon and i want a tranny with lsd lol.</TD></TR></TABLE>
certain b16 tranny from japan has the optional lsd tranny. b16 tranny are NOT bad for boost. I have it in my boosted b18c1 and it works fine on and off the track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet »</TD></TR><TR><TD CLASS="quote">
certain b16 tranny from japan has the optional lsd tranny. b16 tranny are NOT bad for boost. I have it in my boosted b18c1 and it works fine on and off the track. </TD></TR></TABLE>
So does some JDM SiR-G (optional).
The US version did not come with LSD stock and the tranny is hydraulic.
4drferio
Mar 2, 2004 09:45 PM
it is tough to explain tho, i would go with a b16 tranny tho if you are not runing boost
