Suspension & Brakes Theory, alignment, spring rates....
problem installing prothane front endlink bushings on 95 integra ls
Old Dec 26, 2007 | 06:55 PM
atleast-3's Avatar
Default problem installing prothane front endlink bushings on 95 integra ls
my problem is that the prothane bushing is like twice as thick as the oem rubber one. so when i put the two on the lca and the two on the sway bar, theres no room for the nut. my question is do i have to cut the prothane bushings somehow down to the same size as the oem ones? need some input please or maybe i have the wrong endlink kit by mistake?
Old Dec 27, 2007 | 04:02 AM
atleast-3's Avatar
Default Re: problem installing prothane front endlink bushings on 95 integra ls (atleast-3)
c'mon, someone has to know if i need to trim my endlink bushings to fit or not......
Old May 7, 2008 | 05:51 PM
gabebauman's Avatar
Try a C-clamp?
Old Jun 7, 2008 | 06:33 PM
LS-V_T_fullrace_EG's Avatar
beat it with a hammer
Old Jun 7, 2008 | 06:34 PM
or use a JDM hammer... jk hollow it out with a dremel
boxeocampeon
Suspension & Brakes
Apr 27, 2010 06:12 AM
vansxskater
Honda Civic (2001 - 2005)
Apr 16, 2010 02:56 PM
hybrid90
Suspension & Brakes
11
Jun 27, 2009 09:26 PM
CALC!_JUST_du_IT!
Aug 28, 2007 03:19 PM
redman223
Suspension & Brakes
Aug 8, 2007 02:19 PM
