Suspension & Brakes Theory, alignment, spring rates....
ES front endlink bushing nipple to large for DC2 LCA? end link bushing size?
Old Dec 26, 2007 | 04:41 PM
6SPD_EK's Avatar
Default ES front endlink bushing nipple to large for DC2 LCA? end link bushing size?
I am working on piecing together my suspension & I bought some energy suspension front endlinks - to use JUST the endlink bushings (the ones that fit on both sides of the front LCA (running a 24mm GSR front sway & dc2 lca's)
anyways the bushing nipple (nipple is itself 3/8" I.D. & 5/8" O.D) is slightly to big for the hole in the front LCA - is that okay it sits resting on the LCA & not "in" it?
should I try to "trim" the width of the nipple so it fits?
any input would be appreciated - FYI I am trying to use just 4 (2 on each LCA) with a spherical rod ends on the sway bar side of things
here is a pic of 8 of the pieces
Old Dec 26, 2007 | 06:43 PM
PIC Performance's Avatar
Default Re: ES front endlink bushing nipple to large for DC2 LCA? end link bushing size? (6SPD_EK)
I think it's supposed to go like this:
from a jdmuniverse.com how-to.
Old Dec 26, 2007 | 06:52 PM
6SPD_EK's Avatar
Default Re: ES front endlink bushing nipple to large for DC2 LCA? end link bushing size? (PIC Performance)
thanks - yes those are the bushings I am talking about... my question was regarding the nipple on the bushing - I was thinking it should fit in the hole but not sure I think the hole is 1/2" while nipple is 5/8" OD
Old Dec 26, 2007 | 09:27 PM
egsleepercivic's Avatar
I think the sway bar should be above the lca
Old Dec 27, 2007 | 01:07 AM
6SPD_EK's Avatar
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">I think the sway bar should be above the lca</TD></TR></TABLE>
thanks but i know that - pic is probably upside down
what I am asking about is "how the bushing grommet sits" on both sides of the lca - here is a pic to better explain the situation
currently the bushings sit like those drawn in the lower example
Old Dec 29, 2007 | 06:14 AM
6SPD_EK's Avatar
Default Re: (6SPD_EK)
anyone else?
Old Feb 22, 2008 | 11:24 AM
Relic1's Avatar
back from the archive cause I was looking for the diameter of the LCA hole... did you trim it so it sits in the LCA hole? (would have been my suggestion)
Old Feb 27, 2008 | 06:48 AM
6SPD_EK's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">back from the archive cause I was looking for the diameter of the LCA hole... did you trim it so it sits in the LCA hole? (would have been my suggestion)</TD></TR></TABLE>
no - i have not... yet
I plan on getting a set of es endlinks especially for integra to see if the bushing nipples are smaller. I will be sure to update here - I should know in a week or so
amej8
Jul 14, 2011 04:39 PM
billabong
Suspension & Brakes
Oct 29, 2010 04:00 PM
hybrid90
Suspension & Brakes
11
Jun 27, 2009 09:26 PM
AFAccord
Nov 29, 2005 07:36 PM
SHG_EasyE
Mar 29, 2005 03:32 AM
