HELP please...
So I just got rid of my old z6 and got another. All I did was exchange the wire harness(from my car), alternator, distributor, starter, and the intake mani. So I got it all in and all it does is crank. I can smell the fuel but im not getting any expletivein spark. I put new plugs, wires, rotor, checked all grounds, and pretty much everything a million times. Could it be that the injectors plugged in backwards? Once again everything that was on my car in working order was exchanged onto this new motor. The fuel pump still primes, and clicks and I can smell the fuel in the engine so its not the main relay or ecu hopefully.
I appreciate any help or suggestions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Spugen_ »</TD></TR><TR><TD CLASS="quote">So I just got rid of my old z6 and got another. All I did was exchange the wire harness(from my car), alternator, distributor, starter, and the intake mani. So I got it all in and all it does is crank. I can smell the fuel but im not getting any expletivein spark. I put new plugs, wires, rotor, checked all grounds, and pretty much everything a million times. Could it be that the injectors plugged in backwards? Once again everything that was on my car in working order was exchanged onto this new motor. The fuel pump still primes, and clicks and I can smell the fuel in the engine so its not the main relay or ecu hopefully.
Injectors being plugged in "backwards" would not cause you to have no spark.
Check the igniter, rotor, and cap, on your distributor.
</TD></TR></TABLE>Injectors being plugged in "backwards" would not cause you to have no spark.
Ok theres the ground on the vc to the rad support, the ground from the tranny to the little bracket on the tranny, the ground from the distrib wires to the t-stat housing, and most importantly the battery ground.
Am I missing any?
Am I missing any?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Spugen_ »</TD></TR><TR><TD CLASS="quote">Im Assuming this is correct...
yeah thats correct firing order
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Spugen_ »</TD></TR><TR><TD CLASS="quote">If one of the plugs on the intake mani are plugged in the wrong place would that cause it not to start???</TD></TR></TABLE>
You said it's not getting any spark though - it's not like it's just randomly not starting and have no clue what's wrong with it.
If it's not sparking it's one of two issues:
A) Distributor issue
B) Grounding issue
Pick one. I say dizzy if you checked the grounds as many time as you've claimed you have.
B) Grounding issue
I helped a guy yesterday on a problem like this he had the wires on the same way u did but i told him to do it this way and it worked so try it on yours
24
13 thats the cap and the motor is correct
24
Ok I sold my old motor with my old dizzy that worked perfectly fine...The guy who bought it from me let me borrow it and I put it on and still no spark. I also tried a new coil and rotor and still no spark. I guess Ill try to move the ground somewhere else...
alright well on different motors the wires go on different ways like i think the Z6 is the way u have it but wont work on DOHC motors. I did it to my buddys B20 and learned that it didnt work
I have a z6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">Ok what Motor do u have I read your thing over U have a Z6 Or the Motor in that Pic?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_n_FlipFlops »</TD></TR><TR><TD CLASS="quote">maybe timing off? cams,cranks lined up?</TD></TR></TABLE>
The timing is perfect...thats what I thought first and I had a friend set it.
Ive also checked all the fuses and they are all fine...I will double check all the harness plugs though
