Help on Throttle Body
Old Dec 26, 2007 | 12:43 PM
blazin415's Avatar
Default Help on Throttle Body
i was wondering what size is the stock 1995 gsr throttle body. i was planning on picking up a 70mm skunk2 throttle body but wants to know what is stock specs. also will all gsr aftermarket intakes fit on the skunk2 intake manifold?
Old Dec 27, 2007 | 01:22 AM
blazin415's Avatar
Default Re: Help on Throttle Body (blazin415)
also, which throttle body would you guys aim for? a 68mm or a 70mm?
Old Dec 28, 2007 | 06:05 PM
SteamedRice's Avatar
to answer your question, yes it will fit, the coupling on the intake manifold should take care of that.
i have a similar relationship i'm trying to fix, however, i'm a forced induction guy, but i believe the principles are the same. the stock gsr throttle body is 62-64mm (not sure). the skunk2's come in 60, 66, 68, and 70mm. the skunk2 intake manifold port is 64mm and can be port matched up to 75mm without interfering with the IACV port. i've been researching the best set up but here are the things that i got out of research so far:
1. port matching can be costly but would optimize air flow.
2. make sure your throttle body is smaller or the same size as your intake manifold port. if it is larger it promotes reversion of air flow at WOT.
3. skunk2 doesn't make a 64mm thottle body to make things easier .
Modified by SteamedRice at 7:31 PM 12/28/2007
Old Dec 28, 2007 | 06:09 PM
Default Re: Help on Throttle Body (SteamedRice)
some ppl say they lose mid-high range power when they install a new TB. my guess would be that this mod wasn't used in conjunction with a port match or larger intake manifold plenum.
my question is can your TB/IM port be too big? what i mean is, would a 66mm TB/IM port match be better for a street set up (all motor or FI), and a 70-75mm set up for a track car? any input?
/thread jack
Old Dec 28, 2007 | 07:20 PM
Billy_Bob's Avatar
stock gsr =62-60
http://www.homemadeturbo.com/f...241.0
I would buy one of those and save 150 bucks
Old Dec 29, 2007 | 07:04 AM
daver's Avatar
stock gsr is 60mm. stock itr is 62mm. i can't see much reason to go over 64mm all motor.
d
Old Dec 29, 2007 | 11:48 AM
blazin415's Avatar
what size is the stock s2000 throttle body?
Old Dec 29, 2007 | 12:34 PM
Billy_Bob's Avatar
Default Re: (blazin415)
62
Old Dec 30, 2007 | 08:31 AM
blazin415's Avatar
then i should just get the type r intake manifold and throttle body instead?
Old Dec 30, 2007 | 09:18 AM
00Red_SiR's Avatar
All Motor Mentor
search "max bore" on here.
Old Dec 30, 2007 | 01:20 PM
daver's Avatar
i wouldn't bother with an itr intake manifold if you don't want to deal with having to mod it fit, plus its technically not angled properly for gsr intake runners anyway.
itr tb is a waste if you can do without you're stocker for a few days, get it bored 2 or 4mm at maxbore, any more than that is for boost imo.
95egianp
Mar 18, 2013 04:46 PM
shahriar35
Jan 31, 2010 12:13 AM
slide inside
Oct 21, 2009 01:15 AM
Downz
Oct 26, 2006 08:43 PM
